I have a rather big setup but will keep it to the important things for now. Let’s say I have:
1 Wireless switch
1 Wireless power outlet with a lamp
What I did in openhab2 was to create a rule to switch the outlet to the state of the switch, as soon as a command was received. Easy.
But let’s take a second to think about this: Why not simply link together those 2 things into a single item? So I removed the Item for my wireless switch and added the channel config to my wireless outlet item:
I hope I did understand correctly!
You have a wireless switch and a wireless power outlet. In other words you have a transmitter (switch) and reciever (outlet) which you would like to work directly with each other. If both would be belonging to each other ( are a bundle) that would be the normal and only way of operation.
Using a home automation system you WANT TO be able to share the functionalities of both equipments with other equipments. Your transmitter might be used to send commands to other plugs, the plug might get commands from somewhere else. That gets possible by the home automation . To have that both equipments need to be separated by the system.
I also use multiple rules to control that outlet. This would just take the clutter of an absolute-basic rule away. But yes, I am mostly here for opinions, thank you for yours
openHAB 1.x bindings have access to a very nice feature where one binding can listen for state updates to one of its bound items (using internalReceiveUpdate) and pass the update down to the integrated system. The same item would be bound to another binding as well as a source of these state updates. So, for example, creating an MQTT gateway for the ambient temperature reported by an Ecobee thermostat is as simple as:
Number Temp "Temp [%.1f °F]" { ecobee="<[1234#runtime.actualTemperature]", mqtt=">[broker:/home/temp:state:default]" }
Is there an equivalent capability for openHAB 2 bindings?
