Wow. How cool. That makes my rule super easy. Thanks a lot.
This is the way it looks now: Much more concise…
Item actionControl received command
switch(receivedCommand) {
case "clean": {
logInfo("File", "Moving Natascha Forward to clean dustbin")
actionCommand.sendCommand('app_rc_start')
Thread::sleep(10000) // wait until remote control is activated
actionCommand.sendCommand('app_rc_move[{"omega":0.0, "velocity":0.2, "seqnum":1, "duration":5500}]')
actionCommand.sendCommand('app_rc_end')
remoteControlClean.postUpdate(OFF)
logInfo("File", "Ready for cleaning dustbin")
I just added an additional switch to the actionControl:
Those are really long sleeps. They might be fine for now if this is the only rule you have with sleeps and your rule will only ever be triggered once. However, if the rule needs to run multiple instances at the same time or you need to be able to cancel the activity or if you have long Thread::sleeps in other rules you should use Timers instead.
val Timer vacuumTimer = null
rule "Vacuum control"
case "clean": {
// schedule the rest to happen in 10 seconds
vacuumTimer = createTimer(now.plusSeconds(10), [|
vacuumTimer = null
case "cancel": {
vacuumTimer?.cancel // cancel the timer if it exists
In the above, we have a Timer vacuumTimer. Instead of using a Thread::sleep we schedule the code to run in the future. Since you have two sleeps, we create two timers. But if for some reason you need to cancel, you can now cancel the Timer and it won’t execute that code. With Thread::sleep, you would have to wait up to 20 seconds and the actionCommands would execute no matter what.
Wow Rich,
thanks. I do not fully understand the timer, but it works like a charm. I think you just missed on two ")"
so I changed “]” into “])”
