I can’t offer you a ready solution for how to do it, but I don’t see why you couldn’t. I’d go as far as to say that that’s what OpenHAB is built to do.
You’ll need an item that links to the tcp/upd binding and that changes according to the received info. Another item for the gpio binding and as you wrote yourself a rule that changes the “gpio-item” when the “tcp-item” changes.
To close this topic, if someone else starts from scratch here my solution:
I defined the items:
String UDP_IN "%s" {udp="<[10.0.0.55:*:'REGEX((.*))']"} //udp listens for messages from 10.0.0.55
Switch GPIO_W "GPIO_W" { gpio="pin:26" } //gpio pin 26 definition
Here the rule:
//if udp input is equal string "K_ON" then gpio pin 26 is set to high
rule "GPIO_SET"
Item UDP_IN changed
if (UDP_IN.state == "K_ON")
GPIO_W.sendCommand(ON)
