Dear all,
I am using the comfoair binding 1.9 with openhab 2.0 with connected serial cable to the comfoair 200.
I am able to read different kinds of temperature and successfully control the fan level.
Regarding comfort temperature (target_temperature), I can successfully read the value from device.
But, if I would like to write the value (e.g. by hab panel) I get an exception from comfoair binding.
The item is configured in
comfoair.items:
Number Lueftung_Komfortemperatur “Zieltemperatur [%d]” (Lueftung) {comfoair=“target_temperatur”}
openhab.log:
13:12:04.831 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘Lueftung_Komfortemperatur’ received command 17
13:12:04.922 [INFO ] [marthome.event.ItemStateChangedEvent] - Lueftung_Komfortemperatur changed from 18 to 17
13:12:05.054 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Exception during event dispatch [org.osgi.service.event.Event [topic=openhab/command/Lueftung_Komfortemperatur] {bridgemarker=true, item=Lueftung_Komfortemperatur, command=17} | {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={event.topics=openhab/*, service.pid=org.openhab.comfoair, component.name=org.openhab.binding.comfoair, component.id=223, service.id=363, service.bundleid=227, service.scope=bundle} | Bundle(org.openhab.binding.comfoair_1.9.0 [227])]
java.lang.NullPointerException
at org.openhab.binding.comfoair.handling.ComfoAirCommandType.getAffectedReadCommands(ComfoAirCommandType.java:421)[227:org.openhab.binding.comfoair:1.9.0]
at org.openhab.binding.comfoair.internal.ComfoAirBinding.internalReceiveCommand(ComfoAirBinding.java:107)[227:org.openhab.binding.comfoair:1.9.0]
at org.openhab.core.binding.AbstractBinding.receiveCommand(AbstractBinding.java:97)[176:org.openhab.core.compat1x:2.0.0]
at org.openhab.core.events.AbstractEventSubscriber.handleEvent(AbstractEventSubscriber.java:42)[176:org.openhab.core.compat1x:2.0.0]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:415)[6:org.apache.karaf.services.eventadmin:4.0.8]
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.run(HandlerTask.java:90)[6:org.apache.karaf.services.eventadmin:4.0.8]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_65]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
Does somebody now this problem? Is the issue related to write the value to the comfoair or more linked to internal handling of the binding or configuration of the binding?
Thanks a lot for support.
Best,
Rüdiger
PS: Despite of this target_temperature issue, it looks that the comfoair binding works with comfoair 200.
