- Platform information: RBPi3-32
- Hardware: RBPi3-32
- OS: openHAB -3.0
- Java Runtime Environment: whatever came with openHAB -3.0
- openHAB version: 3.0
- Issue of the topic: Failure to start “Comitup WiFi Management”. Everything else looks good when booting. I have successfully setup WiFi through config. Even after rebooting RBPi and router, still WiFi initialization fails. Without that, no dice for anything useful, of course.
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
You forgot to post any configuration or logs.
I have WIFI disabled on me because it has generated me an IP address here that I can not use.
Hardware
Jan 2 18:31:47 openhab kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Jan 2 18:31:47 openhab kernel: [ 0.000000] Linux version 5.4.79-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1373 SMP Mon Nov 23 13:27:40 GMT 2020
Jan 2 18:31:47 openhab kernel: [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
Jan 2 18:31:47 openhab kernel: [ 0.000000] CPU: div instructions available: patching division code
Jan 2 18:31:47 openhab kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
Jan 2 18:31:47 openhab kernel: [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.
At the next boot then comes the following error message and now it keeps trying to start the service.
syslog
Jan 2 18:46:44 openhab systemd[1]: Starting Comitup Wifi Management...
Jan 2 18:46:45 openhab comitup[2018]: comitup-no-wifi - No wifi devices found
Jan 2 18:46:45 openhab comitup[2018]: Traceback (most recent call last):
Jan 2 18:46:45 openhab comitup[2018]: File "/usr/sbin/comitup", line 33, in <module>
Jan 2 18:46:45 openhab comitup[2018]: sys.exit(load_entry_point('comitup==1.13', 'console_scripts', 'comitup-cmd')())
Jan 2 18:46:45 openhab comitup[2018]: File "/usr/share/comitup/comitup/comitup.py", line 130, in main
Jan 2 18:46:45 openhab comitup[2018]: cdns.state_callback,
Jan 2 18:46:45 openhab comitup[2018]: File "/usr/share/comitup/comitup/statemgr.py", line 171, in init_state_mgr
Jan 2 18:46:45 openhab comitup[2018]: conf.ap_password
Jan 2 18:46:45 openhab comitup[2018]: File "/usr/share/comitup/comitup/states.py", line 322, in init_states
Jan 2 18:46:45 openhab comitup[2018]: nmmon.init_nmmon()
Jan 2 18:46:45 openhab comitup[2018]: File "/usr/share/comitup/comitup/nmmon.py", line 146, in init_nmmon
Jan 2 18:46:45 openhab comitup[2018]: modemgr.get_ap_device(),
Jan 2 18:46:45 openhab comitup[2018]: File "/usr/share/comitup/comitup/modemgr.py", line 68, in get_ap_device
Jan 2 18:46:45 openhab comitup[2018]: ap_device = devs[0]
Jan 2 18:46:45 openhab comitup[2018]: IndexError: list index out of range
Jan 2 18:46:45 openhab systemd[1]: comitup.service: Main process exited, code=exited, status=1/FAILURE
Jan 2 18:46:45 openhab systemd[1]: comitup.service: Failed with result 'exit-code'.
Jan 2 18:46:45 openhab systemd[1]: Failed to start Comitup Wifi Management.
comitup.log
2021-01-02 18:43:17,727 - comitup - INFO - Starting comitup
2021-01-02 18:43:17,731 - comitup - ERROR - comitup-no-wifi - No wifi devices found
2021-01-02 18:43:24,222 - comitup - INFO - Starting comitup
2021-01-02 18:43:24,226 - comitup - ERROR - comitup-no-wifi - No wifi devices found
2021-01-02 18:43:30,720 - comitup - INFO - Starting comitup
2021-01-02 18:43:30,725 - comitup - ERROR - comitup-no-wifi - No wifi devices found
I have now stopped the service and disabled.
