Hi all,
I hope you can help me as I don’t understand what’s happening. I have a simple rule to test the Telegram Action, which is working fine:
rule "Telegram Test"
Item Test_Switch changed
sendTelegram("Bot1","Test successful")
Now I want to combine it with the Fritz Box TR064 binding.
rule "Incomming call"
// fboxRinging is a switch item which switches to ON if call is detected
Item fboxRinging changed from OFF to ON
val incCallResolved = fboxIncomingCallResolved.state as StringListType
val callerName = incCallResolved.getValue(1)
sendTelegram("Bot1", callerName.state.toString + " is calling.")
In the log files I can see, that the caller name is successfully resolved, but none of the telegram messages are send. And I don’t get it why…
Thank you for your help
