Command line help is garbled
I used the TAB key to get a list of command line commands. However the display is all garbled:
openhab>
__directories
__files
__get_scr_components
__load_class
__option_not_present
__set_unset_arguments
__usage_completion
addCommand
audio
automation
bg
break
bundle
bundle:capabilities capabilities        (Displays OSGi capabilities of a given bundles)bund
le:classes classes                                                              (Displays a list of classes/resources contained in the bundle)bundle:d
iag diag        (Displays diagnostic information why a bundle is not Active)bundle:dynam
ic-import dynamic-import                                                          (Enables/disables dynamic-import for a given bundle)bundle:find-clas
s find-class        (Locates a specified class in any deployed bundle)bundle:headers heade
rs        (Displays OSGi headers of a given bundles)bundle:id id
        (Gets the bundle ID)bundle:info
        (Displays detailed information of a given bundles)bundle:install install
        (Installs one or more bundles)bundle:list list
        (Lists all installed bundles)bundle:load-test load-test
        (Load test bundle lifecycle)bundle:refresh refresh
        (Refresh bundles)bundle:requirements requirements
                                                   (Displays OSGi requirements of a given bundles)bundle:resolve resolve
        (Resolve bundles)bundle:restart restart
        (Restarts bundles)bundle:services services
                                                      (Lists OSGi services per Bundle)bundle:start start
        (Starts bundles)bundle:start-level start-level
                                    (Gets or sets the start level of a bundle)bundle:status status
                                           (Get the bundle current status)bundle:stop stop
                                                        (Stop bundles)bundle:tree-show tree-show
       (Shows the tree of bundles based on the wiring information)bundle:uninstall uninstall
                                           (Uninstall bundles)bundle:update update
                                           (Update bundle)bundle:watch
                         (Watches and updates bundles)cancel config:cancel        (Canc
els the changes to the configuration being edited)cat
cd
cl
I am using a window size of 150x53. Is there a recommended window size?
Win7 64bit
