This widget is derived from the ButtonON widget from @Bernd_Ritter. It adds the option to specify the command that is sent to the item when the button is activated. The button will remain in a visual activation stage filled with color as long as the item remains in that state.
Screenshots
Example:
Example when active:
Configuration of the example:
Changelog
Version 0.1
- initial release
Resources
The YAML code for the widget:
uid: CommandButton
tags:
- button
- standalone
props:
parameters:
- default: Command Button
description: Text to show as title.
label: Title
required: true
type: TEXT
groupName: display
- default: Start
description: Text to show on the button.
label: Button
required: true
type: TEXT
groupName: display
- context: item
description: Item to use with this button.
label: Item
required: true
type: TEXT
groupName: item
- default: ON
description: Command to send to the item.
label: Command
required: true
type: TEXT
groupName: item
parameterGroups:
- name: display
label: Display Options
- name: item
label: Item
timestamp: Jan 21, 2023, 6:53:53 AM
component: f7-card
title: =props.title
slots:
default:
- component: f7-block
class: bog
style:
display: flex
flex-wrap: wrap
justify-content: space-between
align-content: space-between
padding: 20px
slots:
default:
- component: oh-button
text: =props.button
outline: true
actionItem: =props.item
actionCommand: =props.command
action: command
active: =(items[props.item].state === props.command)
style:
width: 100px
