Good afternoon.
Running OpenHABian (app 3.1) and I wanted to create a Rule that whenever I manually told it to run, it would kick off the “openhab-cli backup” command.
Poking around in the various threads, I found that I should be able to create this rule:
triggers: [ ]
conditions: [ ]
actions:
- inputs: { }
configuration:
type: application/javascript
script: |
executeCommandLine(“sudo openhab-cli backup”)
type: script.ScriptAction
I’ve also added the following line to the SUDOERS file:
openhab ALL=(ALL) NOPASSWD: /usr/bin/openhab-cli
I’ve even played with the SUDOERS file being “openhabian” instead, but neither seem to work. I click play on the rule, it runs for a second, but no new/additional backup files are made.
Clearly I’m missing something, but in theory I’ve given that user rights to run the command w/o password prompting. Does anyone see anything glaringly wrong with this as to why it wouldn’t work?
Thanks…
