Since a new installation with openHAB 2.5.0 ~ S1611-1 there are daily problems in event.log or frontail:
2019-06-15 09:06:52.515 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:7f56ae25:node17' has been updated.
2019-06-15 09:08:07.359 [hingStatusInfoChangedEvent] - 'zwave:device:7f56ae25:node17' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller
Always after the daily heal change 5 battery devices about 30x from online to offline and back to online. Sometimes the COMMUNICATION_ERROR takes a few minutes, sometimes 1-2 hours. Everything takes place between 2 in the morning and 10 in the morning. From 10 am to 2 am all battery devices are updated normally. It was not before reinstalling and I have not changed anything else. There are always the same 5 nodes affected by 6 battery devices. Also no problems make the battery thermostats (flirs). What could that be?
Generally this will be caused by 3 timeouts in a row. Or, it could be caused by no communications for twice the wakeup period since this is a battery device.
You should check the debug logs to see what is happening.
Unfortunately I can not call the DEBUG mode at the moment. Alexa always reported that all the devices are currently not reporting and myobenHAB was always offline.
In the German forum I read that one should change to another Java8 version. That was a big mistake. The installation failed.
Since then, no OH goes.
When I enter ssh openhabian @ openhabianpi in the terminal:
Every 2.0s: cat /boot/first-boot.log``
2019-06-17_12:17:19_CEST [openHABian] Starting the openHABian initial setup.
2019-06-17_12:17:19_CEST [openHABian] Storing configuration... OK
2019-06-17_12:17:19_CEST [openHABian] Changing default username and password... SKIPPED
2019-06-17_12:17:19_CEST [openHABian] Setting up Wi-Fi connection... OK
2019-06-17_12:17:19_CEST [openHABian] Ensuring network connectivity... OK
2019-06-17_12:17:20_CEST [openHABian] Waiting for dpkg/apt to get ready... OK
2019-06-17_14:45:16_CEST [openHABian] Updating repositories and upgrading installed packages... OK
2019-06-17_14:45:25_CEST [openHABian] Installing git package... OK
2019-06-17_14:45:34_CEST [openHABian] Cloning myself... FAILED
2019-06-17_14:45:34_CEST [openHABian] Initial setup exiting with an error!
When I entered “sudo openhabian-config” and performed all updates, but only until the first boot.log
In the browser, there are only errors when connecting, even in the Finder under “with server connect” only errors.
When reinstalling with an new SD and openhabian image, the installation always hangs when updating. What can I do?
