Dear Community,
I have 3 gaz stations in my proximity and I want my basicUI (eventually my HabPanel when I figured out how to work it) to only show the cheapest station
so I am thinking of a rule with something like:
rule "figure out the cheapest station"
Item Station1 received update or
Item Station2 received update or
Item Station3 received update
var station1 = ??
//what do I need to put here, so that var station1 equals the prize of Station 1
var Station2=
var Station3=
var min
if
(Station1 <= Station2 && Station1 <= Station3)
{var min==Station1}
else if
(Station2 <= Station1 && Station2 <= Station3)
{var min==Station2}
else
var min==Station3
something like that.
A couple of problems I run into when thinking about it:
how do i now which station actually has the lowest value? And how do I put that rule in proper syntax.
I feel quite stupid…
Thanks guys
It’s not so diffuclt with three. Compare A and B to find the lowest. Now compare that with C and choose the lowest of that pair. That’ll be the lowest of three.
Thanks Sascha,
that does work actually - an approach I would have never come up with.
Unfortunately it leads to 2 new problems:
1st: one of the 3 stations is only open at certain times.
But when closed the price equals 0, hence the MIN Group returns 0 - behavior which is not intended.
2nd:
I do not only want to display the value of the Min station, but also which Station the value is from. In fact the sitemap should only show the price in € of the cheapest Station together with its name…
To be honest, I initially thought that you want also the name of the gas station displayed.
So therefore we might need a proxy item:
String CheapestGasStation
and then a rule that writes the name of the station and the current value to this item:
rule "My cheapest gas station"
Item gGasStations changed
gGasStations.allMembers.forEach [ item |
if(item.state == gGasStations.state){
CheapestGasStation.sendCommand(item.toString() + item.state.toString())
i didn’t test this code so it might have some typos but the idea would be:
Iterating through all items within the group and if you find an item has got the same value as the group, this item name and it’s value should then be sent to the proxy Item.
You still can format the string that you are passing through sendCommand to your needs.
So there’s only one drawback - you still have the problem that the group value is 0 when a station is closed and therefore you would display the 0 value together with its item name.
So maybe instead of looking for the item that has the same value as the group, you might iterate through all items and still look for the lowest that it not 0.
Don’t have a good example for that so i think you’re a bit on your own for now
CheapestGasStation.sendCommand(item.toString(Label) + item.to.string(State))
Returns this in the logfile:
CheapestGasStation changed from NULL to tanken_stuhr_hem_diesel (Type=NumberItem, State=1.149, Label=HEM Moordeich Diesel, Category=null, Groups=[Tanken, gGasStations])1.149
So all the Information is right there in the log file. Now I just need to extract it into some kind of format to show on my Sitemap (Desired would be “LABEL” followed by State + € - so in my example it would return: “HEM Moordeich Diesel 1,149 €”)
However putting
Text item=CheapestGasStation
does not return anything.
Text item=gGasStations
At least gives me the value of the Station (so 1,149€ in my case)
works pretty well. It only does not acknowledge the spaces but that is fine with me (meaning " " does not make a difference to " ").
The only weird thing is that normally the price is shown with comma (,) but stated formatting returns a (.) But that is a fact I can also live with for now.
