When i run the command from this directory, mvn clean install -DskipChecks, I get a BUILD failure.
[ERROR] The goal you specified requires a project to execute but there is no POM in this directory (C:\wamp\www\org.openhab.ui.habpanel\2.4.0). Please verify you invoked Maven from the correct directory. -> [Help 1]
Can anyone suggest a course of action? @ysc . It seems like im not in the right directory?
I’m not sure what you’re trying to do. Do you want to build HABpanel from the latest 2.5 sources? If so, why don’t you just download the latest jar file from Cloudbees?
To build it from the latest sources, you would first clone the entire webui repo, then change to the bundles/org.openhab.ui.habpanel directory and run mvn clean install. Something like this.
In the 2.4 stable, was there a web-ui build that had HabPanel in it? I cant seem to find it. I need to build off 2.4, not 2.5 as my changes were based on 2.4.
cloning the repository gives me the latest which wont work for this.
23:24:56.024 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.ui.habpanel-2.5.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.ui.reactor.bundles [198]
Unresolved requirement: Import-Package: io.swagger.annotations; version="[1.5.0,2.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: com.google.gson; version="[2.8.0,3.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
