Hi, this is my first problem which I can’t solve by myself or by searching in this forum.
Background info: I live in an apartment which has the “HomeMatic Wireless Room Thermostats” and “HomeMatic Wireless Switch Actuators” build in. So I just bought an CCU2 and connected everything with openhab. The system works great. The switches are connected directly to the thermostats so I can have a backup solution through the CCU2 if one day openhab stops working. So I have to say to the thermostat what temperature I need instead of switching the switches directly ON/OFF.
Here are the used Items
Number Temp_Wohnen "Wohnen Temperatur [%.1f °C]" {channel="homematic:HM-TC-IT-WM-W-EU:64bfae6d:MEQ0089370:2#ACTUAL_TEMPERATURE"}
Number Soll_Temp_Wohnen "Wohnen Soll Temperatur [%.1f C]" {channel="homematic:HM-TC-IT-WM-W-EU:64bfae6d:MEQ0089370:2#SET_TEMPERATURE"}
Group:Switch:OR(ON,OFF) gAnwesenheit "Anwesenheit [MAP(presence.map):%s]"
Switch Urlaub "Urlaub"
Number Heizung_Zusatz "Temperatur Zusatz [%.1f °C]"
Switch Schlafen_Wochentage "Schlafen Wochentage"
And here the Rule
rule "Wohnen Heizen"
Item Temp_Wohnen changed or
Item gAnwesenheit changed or
Item Schlafen_Wochentage changed or
Item Urlaub changed
var Number solltemphoch = 23
var Number solltempmittel = 19
var Number solltemptief = 12
var Number isttemp = Temp_Wohnen.state as DecimalType
var Number hysteresis = 1
var Number zusatz = Heizung_Zusatz.state as DecimalType
/* Heizung Anwesend Wach */
if (gAnwesenheit.state == ON && Schlafen_Wochentage.state == OFF){
if (isttemp <= (solltemphoch - hysteresis)) { Soll_Temp_Wohnen.sendCommand(solltemphoch + hysteresis + zusatz) }
else if (isttemp > (solltemphoch + hysteresis)) { Soll_Temp_Wohnen.sendCommand(solltemphoch - hysteresis + zusatz) }
/* Heizung Anwesend Schlafen */
else if (gAnwesenheit.state == ON && Schlafen_Wochentage.state == ON){
if (isttemp <= (solltempmittel - hysteresis)) { Soll_Temp_Wohnen.sendCommand(solltempmittel + hysteresis + zusatz) }
else if (isttemp > (solltempmittel + hysteresis)) { Soll_Temp_Wohnen.sendCommand(solltempmittel - hysteresis + zusatz) }
/* Heizung nicht Anwesend */
else if (gAnwesenheit.state == OFF && Urlaub.state == OFF){
/* Heizung Urlaub */
else if (gAnwesenheit.state == OFF && Urlaub.state == ON){
if (isttemp <= (solltemptief - hysteresis)) { Soll_Temp_Wohnen.sendCommand(solltemptief + hysteresis + zusatz) }
else if (isttemp > (solltemptief + hysteresis)) { Soll_Temp_Wohnen.sendCommand(solltemptief - hysteresis + zusatz) }
Eclipse dosen’t give me any error. Karaf loads the rule normaly without error. BUT the rule won’t execute. If an Item “changed” Openhab does nothing. Somehow it gets ignored. When I replace the rule with an easy ON/OFF switch like
Item Urlaub changed
switch.sendCommand(ON)
it fires without hesitation. So I think something with the rule is not correct.
Could someone please look at the rule and give me a hint?
So now the rule ends but it still skips the other “if”. I am trying/triggering the rule with the “Schlafen_Wochentage Switch” so it should do the first or the second “if”.
You are right. The rule syntax is correct. Also correct are the calculations. Due to your tip to add some logging to the rule I could manage to find where the problem resides. It is in the presence (FritzTR064) bindning which has detection problems with their new wifi-mesh system. I hope they figure it out so it doesn’t come to interupts anymore.
I am posting the final working rule code for everyone who needs heating calculations based on hysteresis, vacation, sleeptime, presence and logging info.
Item Temp_Wohnen received update or
Item Urlaub changed
var Number solltempanwesend = 17
var Number solltempschlafen = 18
var Number solltempnichtanwesend = 16
var Number solltempurlaub = 12
if (isttemp <= (solltempanwesend - hysteresis)) {logInfo("wohnen.rules", "Condition1/1") Soll_Temp_Wohnen.sendCommand(solltempanwesend + hysteresis + zusatz)}
if (isttemp > (solltempanwesend + hysteresis)) {logInfo("wohnen.rules", "Condition1/2") Soll_Temp_Wohnen.sendCommand(solltempanwesend - hysteresis + zusatz)}
if ((isttemp >= (solltempanwesend - hysteresis)) && (isttemp <= (solltempanwesend + hysteresis))) {logInfo("wohnen.rules", "Condition1/im Hysteresebereich")}
if (isttemp <= (solltempschlafen - hysteresis)) {logInfo("wohnen.rules", "Condition2/1") Soll_Temp_Wohnen.sendCommand(solltempschlafen + hysteresis + zusatz)}
if (isttemp > (solltempschlafen + hysteresis)) {logInfo("wohnen.rules", "Condition2/2") Soll_Temp_Wohnen.sendCommand(solltempschlafen - hysteresis + zusatz)}
if ((isttemp >= (solltempschlafen - hysteresis)) && (isttemp <= (solltempschlafen + hysteresis))) {logInfo("wohnen.rules", "Condition2/im Hysteresebereich")}
if (isttemp <= (solltempnichtanwesend - hysteresis)) {logInfo("wohnen.rules", "Condition3/1") Soll_Temp_Wohnen.sendCommand(solltempnichtanwesend + hysteresis + zusatz)}
if (isttemp > (solltempnichtanwesend + hysteresis)) {logInfo("wohnen.rules", "Condition3/2") Soll_Temp_Wohnen.sendCommand(solltempnichtanwesend - hysteresis + zusatz)}
if ((isttemp >= (solltempnichtanwesend - hysteresis)) && (isttemp <= (solltempnichtanwesend + hysteresis))) {logInfo("wohnen.rules", "Condition3/im Hysteresebereich")}
if (isttemp <= (solltempurlaub - hysteresis)) {logInfo("wohnen.rules", "Condition4/1") Soll_Temp_Wohnen.sendCommand(solltempurlaub + hysteresis + zusatz)}
if (isttemp > (solltempurlaub + hysteresis)) {logInfo("wohnen.rules", "Condition4/2") Soll_Temp_Wohnen.sendCommand(solltempurlaub - hysteresis + zusatz)}
if ((isttemp >= (solltempurlaub - hysteresis)) && (isttemp <= (solltempurlaub + hysteresis))) {logInfo("wohnen.rules", "Condition4/im Hysteresebereich")}
Thank you Garry for pointing me to the right direction.
