Hello there,
I am using openHAB 2.5.1-2
“in short i can’t connect the deconz while the conbee is connected to the raspberry”
i ordererd a conbee 2 to expand my smarthome system.
The Configuration was a bit tricky, I connected the USB stick to my main PC to test the whole setup with Xiaomi sensors.
first, I get the IP address which was my “home pc” IP address, and the API key
After that, I created the bridge in the .things file
I could also connect in openhab the gateway and add the sensors to my sitemap.
this works great
The next step was, to connect the Conbee with the USB port from the “openhab raspberry”
So after I connected the USB to a free USB slot I checked the USB devices with ‘lsusb’
The device is correctly discoverd with “Desden Elektronik”
I am not sure but I was able to create a new API key, cause i didn’t find the problem.
so the conbee is connected to the raspberry and I can start the POST Method and get as a response the “new” API key which I bind to my .thing
http://dresden-elektronik.github.io/deconz-rest-doc/getting_started/
I can also add new things with binding.
But the things are not getting updated and I can’t connect with the conbee with my main pc.
This makes me very confused, the only thing I change was to connect it with the raspberry?
It looks like “something” works but 90% are not working when I do it like this.
I tried to reset it to get a new IP Adress for it while it’s connected to the Raspberry but this doesn’t work as well, I am not able to connect anymore.
I think its a network Problem with my Raspberry or a USB Problem?
Can someone help with it?
Greetings and thank u
