Concat Strings and create itemName out of it
All,
I have a string (“W_OWM_Temp”) and an int number (look0) and would like to create the item name out of them:
var tempS0 = "W_OWM_Temp" + look0.toString as GenericItem
Goal is to post an Update of this very item into another item like this:
W_OWM_TempDay0.postUpdate(tempS0.state)
but I already fail at as GenericItem:
Cannot cast from String to GenericItem
Any help would be greatly appreciated.
This might help:
I found that (I am checking for available threads of course) :wink:
That’s where I got the “as GenericItem” from.
But obviously I did not find the right syntax yet…
import org.eclipse.smarthome.model.script.ScriptServiceUtil
rule "something"
val testItem = ScriptServiceUtil.getItemRegistry.getItem(tempS0)
W_OWM_TempDay0.postUpdate(testItem.state)
Thanks - I will give it a try.
This is essentially what Design Pattern: Associated Items is about.
