I want to condition the behaviour of a hue light based on the fact that it is daytime or night. In a different topic I found some code to determine ‘Daylight’ based on Astro binding
Everything works fine except I am unable to condition ‘Daylight’ in my rule that conditions the light
I already tried to add one the 3 possibilities below for the rule “TURN ON LIGHT 3 RED NIGHT” that I found in browsing the forum but nothing works.
// if
// (Daylight.state == OFF)
// (Daylight == OFF)
// item Daylight == OFF
Any pointers that would help me to condition the rule based on the state of ‘Daylight’ would be appreciated. I know this is going to be something basic but I am giving up after searching the whole weekend …
Many thanks
Christophe
.items
// Astro
DateTime Sunrise_Time "Sunrise [%1$tH:%1$tM]" { channel="astro:sun:home:rise#start" }
DateTime Sunset_Time "Sunset [%1$tH:%1$tM]" { channel="astro:sun:home:set#start" }
Switch Sunrise_Event "" { channel="astro:sun:home:rise#start" }
Switch Sunset_Event "" { channel="astro:sun:home:set#start" }
Switch Daylight "Daylight"
// Niko HomeControl
Switch Gang "Gang" <light> ["Lighting"] {channel="nikohomecontrol:onOff:nhc:27:switch"}
// Hue Bulb3
Switch Light3_Toggle { channel="hue:0210:0017886e4310:3:color" }
Dimmer Light3_Dimmer { channel="hue:0210:0017886e4310:3:color" }
Color Light3_Color { channel="hue:0210:0017886e4310:3:color" }
Dimmer Light3_ColorTemp { channel="hue:0210:0017886e4310:3:color_temperature" }
String Light3_Alert { channel="hue:0210:0017886e4310:3:alert" }
Switch Light3_Effect { channel="hue:0210:0017886e4310:3:effect" }
.rules
// ------------------------CONTROL DAYLIGHT
rule "Set Daylight"
Item Sunrise_Event received update ON
postUpdate(Daylight, ON)
rule "Set night"
Item Sunset_Event received update ON
postUpdate(Daylight, OFF)
rule "Start Daylight"
System started
if
(now.isAfter((Sunrise_Time.state as DateTimeType).calendar.timeInMillis)&& !now.isAfter((Sunset_Time.state as DateTimeType).calendar.timeInMillis))
{ postUpdate(Daylight, ON) }
else
{ postUpdate(Daylight, OFF) }
// this is the rule that creates issues and where i need help as none of the 3 options for the IF work
rule "TURN ON LIGHT 3 RED NIGHT"
Item Gang changed from OFF to ON
if (Daylight == OFF)
{ sendCommand(Light3_Color,HSBType::RED)}
// i tried any of the three below
// if
