Hi all
I am rewriting modbus binding, have the following (rather ugly) xml file
<?xml version="1.0" encoding="UTF-8"?>
<thing:thing-descriptions bindingId="modbus"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:thing="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0"
xsi:schemaLocation="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0 http://eclipse.org/smarthome/schemas/thing-description-1.0.0.xsd">
<thing-type id="slave">
<supported-bridge-type-refs>
<bridge-type-ref id="tcp" />
</supported-bridge-type-refs>
<label>Modbus Tcp Slave Thing</label>
<description>Tcp connected Modbus slave</description>
<channels>
<channel id="switch" typeId="switch-type" />
<channel id="contact" typeId="contact-type" />
</channels>
<config-description>
<parameter name="slave-param" type="integer">
<label>slave-param</label>
<description>slave-param</description>
</parameter>
</config-description>
</thing-type>
<channel-type id="switch-type">
<item-type>Switch</item-type>
<label>Modbus Switch</label>
<description>switch item channel for Modbus Binding</description>
<parameter name="switch-param" type="integer">
<label>switch-param</label>
<description>switch-param</description>
</parameter>
</channel-type>
<channel-type id="contact-type">
<item-type>Contact</item-type>
<label>Modbus Contact</label>
<description>contact item channel for Modbus Binding</description>
</channel-type>
</thing:thing-descriptions>
When adding the slave thing to the paper UI I cannot see “switch-param” parameter input field. Is there something wrong with my xml?
Thanks in advance
