mougeat
(Cyril Barthel)
November 24, 2018, 4:19pm
1
Dear all
I have recently installed OpenHab in order to us it with my MyHome installation.
I have activated the Biticino Binding. In services in biticino.cfg file My code is
# Host and port of the default OpenWeb bticino IF
# OpenWeb gateway IP address / Hostname
default.host=192.168.0.74
# OpenWeb gateway Port (optional, defaults to 20000)
#default.port=
# OpenWebNet gateway password (optional, defaults to 12345)
default.passwd=12345
# OpenWeb bus status rescan interval (optional, defaults to 120 seconds)
#default.rescan_secs=
# OpenWebNet Number of heating zones (optional, 0 - 99 defaults to 0)
#default.heating_zones=
# OpenWebNet Run Time of RollerShutter to calculate Position Feedback (optional, defaults to 0 milliseconds)
#default.shutter_run_msecs=
How can I see if I am conected to my webserver ?
Thanks for your help.
H102
(CM6.5 H102)
November 24, 2018, 4:29pm
2
Have you looked at the OH logs?
mougeat
(Cyril Barthel)
November 25, 2018, 6:02am
3
Hello
Yes but in my log File (openhab-tmpfs.log) nothings has changed since my new installation yeasterday morning
2018-11-21 20:51:19> -----------------------------------------------------------------
2018-11-21 20:51:19> called with start
2018-11-21 20:51:19> start: directory /var/services/homes/openhab/tmpfs exists => removing
2018-11-21 20:51:19> creating /var/services/homes/openhab/tmpfs/userdata/logs
2018-11-21 20:51:19> deleting /var/services/homes/openhab/userdata/logs
2018-11-21 20:51:19> creating /var/services/homes/openhab/userdata/logs
2018-11-21 20:51:19> linking /var/services/homes/openhab/tmpfs/userdata/logs to /var/services/homes/openhab/userdata/logs
2018-11-21 20:51:19> creating /var/services/homes/openhab/tmpfs/userdata/persistence
2018-11-21 20:51:19> deleting /var/services/homes/openhab/userdata/persistence
2018-11-21 20:51:19> creating /var/services/homes/openhab/userdata/persistence
2018-11-21 20:51:19> linking /var/services/homes/openhab/tmpfs/userdata/persistence to /var/services/homes/openhab/userdata/persistence
2018-11-21 20:51:19> start: copied Saved to TMPFS
2018-11-24 06:36:01> -----------------------------------------------------------------
2018-11-24 06:36:01> called with stop
2018-11-24 06:36:01> stop: copied TMPFS to Saved
2018-11-24 06:36:01> stop: directory /var/services/homes/openhab/tmpfs exists => removing
2018-11-24 06:42:09> -----------------------------------------------------------------
2018-11-24 06:42:09> called with start
2018-11-24 06:42:09> start: directory /var/services/homes/openhab/tmpfs exists => removing
2018-11-24 06:42:09> creating /var/services/homes/openhab/tmpfs/userdata/logs
2018-11-24 06:42:09> deleting /var/services/homes/openhab/userdata/logs
2018-11-24 06:42:09> creating /var/services/homes/openhab/userdata/logs
2018-11-24 06:42:09> linking /var/services/homes/openhab/tmpfs/userdata/logs to /var/services/homes/openhab/userdata/logs
2018-11-24 06:42:09> creating /var/services/homes/openhab/tmpfs/userdata/persistence
2018-11-24 06:42:09> deleting /var/services/homes/openhab/userdata/persistence
2018-11-24 06:42:09> creating /var/services/homes/openhab/userdata/persistence
2018-11-24 06:42:09> linking /var/services/homes/openhab/tmpfs/userdata/persistence to /var/services/homes/openhab/userdata/persistence
2018-11-24 06:42:09> start: copied Saved to TMPFS
Dim
(Angelos)
November 25, 2018, 8:06am
4
what is this? Synology? which SDM version with which JVM?
Which OH2 version are you running?
the logs are found in $userdata/logs
you need to check openhab.log
in there
mougeat
(Cyril Barthel)
November 26, 2018, 10:11am
5
Yeasterday, I have re installed OpenHAb on my synology and today, it is working.
I do not know what was wrong but now, everithing is fine. Thank you for your help.
