openHAB 3.0.2 (release) up and running. Just wanted to know if someone could tell me where the influxdb persistence service writes its configuration to?
Background: after each openhab service restart the configuration falls back to an old value (in my case the “Database URL” has changed and the old value doesn’t work anymore).
To decide which groups/items will be stored in influxdb you need to configure the persistence file: persistence\influxdb.persist
More info: Persistence | openHAB
Some things can be set in the UI under settings, other services, influxDB Persistence. Also under system settings, persistence to set default persistence.
Thanks for coming back - I’m using influxdb since years. What bothers me is if I now change influxdbs’ URL in the GUI (not textual cfg) from “old” to “new” and restart openhab, it loads the config with “old”.
So “new” is just valid/used in the current runtime.
UI control of persistence is very much “under development” i.e.non-functional. I’m surprised the release version actually lets you edit anything, it’s probably not supposed to.
The editing page probably needs a lock-out for xxx.cfg defined properties, rather like trying to edit a file-defined Item etc. does.
