- Platform information:
- Hardware: Raspberry Pi 4
- OS: OpenHabian 1.5
- Java Runtime Environment: ???
- openHAB version: ???
I am just getting started with home automation. I am running OpenHabian (latest version 1.5) and have bought a minimal setup for testing/getting started. It consistis of:
- Raspberry Pi 4
- Bitron Video ZigBee USB Funkstick, which was recommended in the forum for use with the ZigBee binding.
- Hue lamp
- Hue motion sensor
I now found the Hue motion sensor to be too insensitivity enough to movement and I would like to change/increase its sensitivity. This seems to be possible through the Hue REST API using the Hue bridge, which I do not own.
From what I have read/understand here it seems to be possible to configure the sensor sensitivity in deCONZ using its REST API without Hue bridge.
However I cannot use deCONZ, since I am using a different ZigBee stick.
So is there any way of accessing the REST API and/or the corresponding values using the ZigBee binding and the Bitron ZigBee stick?
Should I (instead) switch to the ConBee II stick for deCONZ?! (I could still return my current stick).
Thanks for any advice,
Michael
