I need help configuring my Logitech Harmony Hub volume control as a dimmer switch.
Currently, I can control my volume up/down of my receiver using a simple button command in the item/sitemap. However, I find it very cumbersome if I want to increase the volume by 2 notches. Is there a way to configure my volume control within Openhab as a dimmer switch? (so each 25% increments increases or decreases the volume by 2 or more)
Also, how would this translate when I program it within the Amazon Echo HA Binding configurator (onURL and offURL)?
Any help is appreciated.
I found some similar posts here in the forum and it seems like I need to create a rule in addition to inputting the item and sitemap code, but I don’t understand. My knowledge in programming is pretty limited coming from a graphic design background, but I know how to get around things or tinker my way out of something.
Thanks again for your help.
