I am able to send a test message to the bot using the link https://api.telegram.org/bot/sendMessage?chat_id=&text=testing`
My token is bot103XXXXXXX:AAHYYYYYYYYYYYYIOOz8HEqiFp1-famFAWE
My Chat_ID is 9XXXYYY44 (it does not have a ‘-’ prefix)
When I try setting these in the PAPERUI configuration of the binding to create a “Thing” it does not accept my ChatID (the line under the number remain red) and the tick box remains greyed out so I cannot save.
Can someone tell me what i’m doing wrong ?
Telegram Binding is version 2.5.4
Hi Charley
My problem is I can’t get passed the telegram binding configuration in
Inbox >telegram binging>choose thing
After installing the telegram binding if you conduct a search in the openhab inbox paperui you discover the TelegramBot. It’s the configuration of this I can’t get past.
My understanding being still somewhat new with openhab is that once I can configure the binding a “thing” will be created.
Regards
Kevin
Hi Charley
Thats exactly what Ive done but the “tick” to accept remains greyed out and underneath the chatID entry the line is red not black, which I assume means it does not recoqnise my format of my chatID. However the chatID and token work on api.telegram
