I am new to openHAB (currently using Domoticz).
I have a "KMTronic LAN Ethernet IP 8 channels WEB Relay board"
How would I go about setting this up on openHAB2?
Please point me in the right direction and I will stumble on…
You can use the http binding for this kind of hardware.
That was my initial thought.
I added the following to an items file:
Switch Relay7 { http=">[ON:POST:http://admin:admin@192.168.2.20/FF0701:ON] >[OFF:POST:http://admin:admin@192.168.2.20/FF0700:OFF]" }
and in HABpanel linked a switch to this item.
The problem now is that it only sends the same command “ON” and never “OFF” how do I fix this?
Please try the Switch through REST API, just to ensure if the switch item itself works as expected.
As I wrote I am a beginner. REST API?
If not installed, you can install the REST API documentation, after installation it’s reachable under http://ip.of.openhab.installation:8080/doc/index.html
You can try to use Basic UI either, or try to switch through karaf console. There are several ways to switch a switch
By the way: I think you don’t need a POST body, so
Switch Relay7 { http=">[ON:POST:http://admin:admin@192.168.2.20/FF0701] >[OFF:POST:http://admin:admin@192.168.2.20/FF0700]" }
should suffice.
I checked it in BasicUI using:
and
sitemap default label="My first sitemap"
Switch item=Relay7 label="Relay 7"
and indeed according to the log and actual device the Relay toggles ON/OFF fine.
2017-07-30 20:24:02.321 [ItemCommandEvent ] - Item 'Relay7' received command ON
2017-07-30 20:24:05.329 [ItemCommandEvent ] - Item 'Relay7' received command OFF
but when activated from Switch in HABpanel it only sends the ON commmand:
2017-07-30 20:22:18.306 [ItemCommandEvent ] - Item 'Relay7' received command ON
2017-07-30 20:22:19.010 [ItemCommandEvent ] - Item 'Relay7' received command ON
2017-07-30 20:22:19.689 [ItemCommandEvent ] - Item 'Relay7' received command ON
2017-07-30 20:22:20.313 [ItemCommandEvent ] - Item 'Relay7' received command ON
Is there a problem in HABpanel or have I defined something wrong somewhere?
I think it’s clear that you made some mistake in configuration at habpanel. Unfortunately I can’t help with habpanel, as I don’t use it yet.
I restarted openHAB and now it is working
