You can install a newer Zigbee binding on 2.4. I recommend users this install scrip with IH running.
Iām not sure if it still works with OH 2.4, but @5iver should be available to provide some insights.
Items should be in /etc/openhab2/items/default.items
and your sitemap is probably /etc/openhab2/sitemaps/home.sitemap
That should be fine, Iām using a pi with 1GB ram as well (even with zram enabled for logs and swap).
Afaik @chris has just added support for the Tradfri motion sensors, those might be an optionā¦
I have not been able to get a manual zigbee install working since it was migrated to bnd. And I have not tested anything on 2.4 for quite a while. Rather than copying the jar and dependencies into /addons/, I find it easier to use bundle:update. I plan to update the script, but my interest in OH is waning.
I managed to install the 2.5 SNAPSHOT on 2.4 stable last week - it works fine, but requires the xstream dependency which took me a while to find.
