Thanks, I learned something. I had a bunch of orphaned config files and files with old information in it that caused a lot of startup errors. For the first time in 2 years my startup is perfectly clean with no errors!
I’ll retry configuring network things via file to see if that is fixed later.
Same for me: clean new OH2.4 install on a brand new Windows 10 PC, ICMP ports open in firewall, created network.cfg and deleted network.config but nothing is discovered by the binding whereas it works like a charm in OH2.3.
Adding things manually works: they are pinged and channel are updated properly.
I switched my router for a simple hub and could not understand why devices were not discovered anymore. Glad to see it is by design. I hope the feature comes back, just have to add the devices manually until then.
Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "arping" (in directory "."): error=2, No such file or directory)
Arping installed. Binding stopped working after updating to 2.4.
