if you set the IP it should immediatly say
[DEBUG] [ternal.discovery.ConnectSDKDiscovery] - localIP parameter explicitly set to: 192.168.0.6
are you using the latest version of the binding?
I wasnât apparently, thanks!
I can use it now using the paper UI, but I am a little bit new to openhab2 and wonders how to config everything manually. I canât find any thing-config anywhere in your posts or documentation, is that not needed? Only items?
Set up a couple of items. You can do this in the items file or in paper ui (these will be stored in the paper ui database). I am personally using the traditional items file.
then go to paper ui configuration page for things and bind the TVâs channels to items.
Tried that, works fine! Btw, it seems the TV doesnât power on if I let it be for a while, I guess it goes to some kind of sleep mode. Do I need to combine WOL with the power command somehow or how have you solved this?
yes, you have to combine it with the WOL binding.
Switch LG_TV0_Power "TV Power" <television> (Entertainment)
Switch LG_TV0_WOL { wol="192.168.2.255#3c:cd:93:c2:20:e0" }
rule "Power on TV via Wake on LAN"
Item LG_TV0_Power received command ON
sendCommand( LG_TV0_WOL, ON)
You also have to enable WOL on your TV. See the screenshot I posted earlier. We already found out in this forum that not all LG TVs support this though.
Hi again, have experimented with your suggested solution, but it seems very unstable at least with my system. Sometimes the TV starts, sometimes it doesnât. Sometimes my gui (habpanel) thinks the the TV is on while itâs off and vice versa. I even tried to have separate buttons for power on and WOL while testing, but I canât see any logic to when it works and when it doesnât. Seem like the binding just finds the TV sometimes and then sometimes itâs gone again. Can I enable debug for your binding somehow? All I see right now is these kind of prints:
14:57:05.838 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'connectsdk:WebOSTV:192_168_0_5' changed from ONLINE: Device Ready to OFFLINE
14:58:51.705 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'connectsdk:WebOSTV:192_168_0_5' changed from OFFLINE to ONLINE: Device Ready
Also I might add that I use wifi for my TV, not sure if WOL is less stable on that, but I donât think it should be.
Hi @all,
can you tell me, how to launch an app e.g. amazon video?
Do I have to assign the app name string to the openhab app string variable via rule? Or how does this work?
Best
Malte
Please see my post on 26-Feb:
Thank you very much! I must have missed this while browsing the threadâŠ
Sorry
no worries. this thread can not replace a proper documentation. it is a TODO
Hi sprehn,
first of all thanks for the good work done for this binding. Highly appreciated.
I use OH2 at the moment I have some remarks regarding to your documentation.
under OH2, when defining items one should use the new format instead of the one used in OH1 for linking items to channels:
for OH1:
String LG_TV0_Toast { connectsdk="lgwebostv.fritz.box:ToastControl:toast" }
for OH2:
String LG_TV0_Toast { channel="connectsdk:WebOSTV:192_168_178_21:toast"}
the command
LG_TV0_Toast.sendCommand("Welcome to Openhab")
works fine in rules, but it displays the OH logo icon. I did not find any way to use method showToast.
Help appreciated.
There is really a need to create a OH2 documentation. You were looking at the 1.8 version. Does somebody have experience how to prepare the docu for OH2 plugins.
I also think it is time to think about merging this plugin into the official project. I will remove a couple of channels that are available via rule actions now.
@Alexus1211 how to use the action with custom icons is documented in this thread a couple of posts up.
Thanks,
it works now. I just needed to include import org.openhab.binding.connectsdk
in order to make it work, otherwise showToast
was causing an error in the logs.
Cheers
I also have a problem with my LG TV. With me runs OH2 on a Windows machine. I installed the most recent version âConnectsdk Binding 2.1.0 snapshot 201703262307â. The connection also works so far up on the appLauncher.
In the log I always get the following error message:
2017-05-04 21:41:46.162 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command ânetflixâ for item âLG_TV0_Appâ to handler for channel âconnectsdk:WebOSTV:192_186_2_116:appLauncherâ, because no thing with the UID âconnectsdk:WebOSTV:192_186_2_116â could be found.
2017-05-04 21:41:49.709 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command âcom.webos.app.tvguideâ for item âLG_TV0_Appâ to handler for channel âconnectsdk:WebOSTV:192_186_2_116:appLauncherâ, because no thing with the UID âconnectsdk:WebOSTV:192_186_2_116â could be found.
2017-05-04 21:41:55.100 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command âcom.webos.app.hdmi1â for item âLG_TV0_Appâ to handler for channel âconnectsdk:WebOSTV:192_186_2_116:appLauncherâ, because no thing with the UID âconnectsdk:WebOSTV:192_186_2_116â could be found.
Can you help me there
Thank you
Hi
seems like the channel is not properly bound to your item. Donât think this is an issue with the binding.
Cheers
Sebastian
Hi Sebastian,
Iâve just set up the Connect SDK Binding. The installation was a smooth process. Thanks!
The purpose of most channels are pretty obvious. However, I donât get the purpose of some of the channels. Especially channels that are strings. What kind of values are expected?
connectsdk:WebOSTV:192_168_3_20:program
connectsdk:WebOSTV:192_168_3_20:externalInput
connectsdk:WebOSTV:192_168_3_20:appLauncher
connectsdk:WebOSTV:192_168_3_20:netflixLauncher
connectsdk:WebOSTV:192_168_3_20:huluLauncher
connectsdk:WebOSTV:192_168_3_20:youtubeLauncher
connectsdk:WebOSTV:192_168_3_20:browserLauncher
Thanks!
externalInput can be used to switch to hdmi sources or other external input. However this can also be achieved with the more versatile application (appLauncher) channel.
program is not working for me on my LG. It is supposed to provide additional details. It is read-only anyhow.
I have removed netflix hulu youtube and browser launcher channels again (still have to release this). this is availabe via actions in rules. The reason why these are of type string - you can pass a value to the TV. e.g. a URL to the browser. a netflix movie id to the netflix channel. I could not get youtube to work and donât have hulu to test.
Kind Regards
Sebastian
Sorry guys. I had been on a business trip the last two weeks and have some catching up to do.
I am testing a release candidate now in my own setup. Will share it here after a while.
The next steps would be to create some docu and submit the plugin to the main project.
Hi Sebastian,
Thank you for your input!
I guess âprogramâ wouldnât work for me either. We are watching TV via an external decoder (input via HDMI). Iâm assuming âProgramâ would only show a value when the TV cable is directly inserted in the Television.
I guess externalInput requires inputs like âHDMI1â, âComponentâ, âAV2â,âŠ). Would applauncher work the same way?
Kind regards,
Dries
