Thanks! Just ordered 1 to play with, I will order 4 more if we can get openhab support.
NOTE: This is a pre-order version of the AutoPi 4G/LTE Edition. The pre-order discount is 10%. Estimated shipping is May 2018.
May is still far away. Even though I’m very interested, I’m going to wait and see.
I just ordered mine. Should be shipping this month. They are still offering the 10% discount.
nice device, but 160secs boot-time :S (see https://community.autopi.io/t/device-boot-up-time/309)
Got my 3 units today and get them setup, now I just need to tie them to openhab!
I discovered AutoPi.io with this discussion. It seems great.
What is your experience with the dongle and software ?
Boot time is better ?
Regards, stephan
I came across this thread in a desperate search for an answer on how to connect Traccar to Openhab.
Unfortunately a direct connection of Traccar to openhab does not work (for unknown reasons) therefore I wrote a small python script which converts the Traccar event/position POST messages to MQTT messages:
The python script only includes basic location messages. I will add more as I go (waiting for my car tracker)
server.py
#!/usr/bin/env python3
Very simple HTTP server in python for logging requests
Usage::
./server.py [<port>]
from http.server import BaseHTTPRequestHandler, HTTPServer
import paho.mqtt.client as mqtt #import MQTT client
import logging
import json
import time
class S(BaseHTTPRequestHandler):
def _set_response(self):
self.send_response(200)
self.send_header('Content-type', 'text/html')
self.end_headers()
def do_GET(self):
logging.info("GET request,\nPath: %s\nHeaders:\n%s\n", str(self.path), str(self.headers))
self._set_response()
self.wfile.write("GET request for {}".format(self.path).encode('utf-8'))
def do_POST(self):
delay = 0.1
broker_address="192.168.1.4"
client = mqtt.Client("Traccar") #create new instance
client.connect(broker_address)
content_length = int(self.headers['Content-Length']) # <--- Gets the size of data
post_data = self.rfile.read(content_length) # <--- Gets the data itself
#logging.info("POST request,\nPath: %s\nHeaders:\n%s\n\nBody:\n%s\n", str(self.path), str(self.headers), post_data.decode('utf-8'))
Traccarjson = json.loads(post_data.decode('utf-8'))
if "position" in Traccarjson:
logging.info("Received Position for Device %s (Name: %s, Status: %s), Lat: %s, Lon: %s, Alt: %s, Acc %s ",
str(Traccarjson["position"]["deviceId"]), str(Traccarjson["device"]["name"]), str(Traccarjson["device"]["status"]), str(Traccarjson["position"]["latitude"]),
str(Traccarjson["position"]["longitude"]), str(Traccarjson["position"]["altitude"]), str(Traccarjson["position"]["accuracy"]))
client.publish("Traccar/Position/"+str(Traccarjson["position"]["deviceId"])+"/Latitude", Traccarjson["position"]["latitude"])
time.sleep(delay)
client.publish("Traccar/Position/"+str(Traccarjson["position"]["deviceId"])+"/Longitude", Traccarjson["position"]["longitude"])
time.sleep(delay)
client.publish("Traccar/Position/"+str(Traccarjson["position"]["deviceId"])+"/Location", str(Traccarjson["position"]["latitude"])+"," +str(Traccarjson["position"]["longitude"]))
time.sleep(delay)
client.publish("Traccar/Position/"+str(Traccarjson["position"]["deviceId"])+"/Altitude", Traccarjson["position"]["altitude"])
time.sleep(delay)
client.publish("Traccar/Position/"+str(Traccarjson["position"]["deviceId"])+"/Accuracy", Traccarjson["position"]["accuracy"])
time.sleep(delay)
client.publish("Traccar/Position/"+str(Traccarjson["position"]["deviceId"])+"/LastUpdate", Traccarjson["device"]["lastUpdate"])
time.sleep(delay)
client.publish("Traccar/Position/"+str(Traccarjson["position"]["deviceId"])+"/Name", Traccarjson["device"]["name"])
time.sleep(delay)
client.publish("Traccar/Position/"+str(Traccarjson["position"]["deviceId"])+"/Status", Traccarjson["device"]["status"])
time.sleep(delay)
#logging.info("Sent Position via MQTT")
elif "event" in Traccarjson:
logging.info("Received Event for Device %s (Name: %s, Status: %s), Event: %s",
str(Traccarjson["event"]["deviceId"]), str(Traccarjson["device"]["name"]), str(Traccarjson["device"]["status"]), str(Traccarjson["device"]["status"]))
client.publish("Traccar/Event/"+str(Traccarjson["event"]["deviceId"])+"/Type", Traccarjson["event"]["type"])
time.sleep(delay)
client.publish("Traccar/Event/"+str(Traccarjson["event"]["deviceId"])+"/LastUpdate", Traccarjson["device"]["lastUpdate"])
time.sleep(delay)
client.publish("Traccar/Event/"+str(Traccarjson["event"]["deviceId"])+"/Name", Traccarjson["device"]["name"])
time.sleep(delay)
client.publish("Traccar/Event/"+str(Traccarjson["event"]["deviceId"])+"/Status", Traccarjson["device"]["status"])
time.sleep(delay)
#logging.info("Sent Event via MQTT")
else:
logging.info("Unknown POST request,\nPath: %s\nHeaders:\n%s\n\nBody:\n%s\n", str(self.path), str(self.headers), post_data.decode('utf-8'))
client.publish("Traccar/Debug",post_data.decode('utf-8'))
#logging.info("Sent Unknown Message")
self.wfile.write("POST request for {}".format(self.path).encode('utf-8'))
def run(server_class=HTTPServer, handler_class=S, port=8080):
logging.basicConfig(level=logging.INFO)
server_address = ('', port)
httpd = server_class(server_address, handler_class)
logging.info('Starting httpd...\n')
try:
httpd.serve_forever()
except KeyboardInterrupt:
pass
httpd.server_close()
logging.info('Stopping httpd...\n')
if __name__ == '__main__':
from sys import argv
if len(argv) == 2:
run(port=int(argv[1]))
else:
run()
Edit: to make this script run as a service I had to add delays between the client.publish functions …
traccar configuration (goes in traccar.xml)
<entry key='event.forward.enable'>true</entry>
<entry key='event.forward.url'>http://127.0.0.1:8099</entry>
<entry key='forward.enable'>true</entry>
<entry key='forward.url'>http://127.0.0.1:8099</entry>
<entry key='forward.json'>true</entry>
please note that I run the python script on the same server as traccar.
Everything runs on a Raspi Zero.
I am not really good at programming … any improvements to the script are very welcome
