same same
seems to be a general problem
login to the portal, maybe you need to give a consent to updated T&Cs, update to the latest binding version should bring up a proper error message
logged in at portal, but nothing to accept :-o
changed from carnet 3.1.0 to latest org.openhab.binding.connectedcar-3.2.0-SNAPSHOT.
First try produced same result.
Second try brought the bridge online and found the two cars.
When I started to create the car things, the channels did not populate.
Re-started the bridge and now itâs offline again:
2021-10-24 17:20:29.037 [DEBUG] [nectedcar.internal.api.ApiHttpClient] - Audi: HTTP GET https://app-api.live-my.audi.com/myaudiappidk/v1/openid-configuration
2021-10-24 17:20:29.145 [DEBUG] [nectedcar.internal.api.ApiHttpClient] - Audi: HTTP 404 Response: service not found:- /myaudiappidk/v1/openid-configuration
2021-10-24 17:20:29.147 [DEBUG] [dcar.internal.handler.AccountHandler] - Audi: Initialization failed: API call failed
Hi @markus7017
At one point the binding was working with Audi USA (I did some testing with you over a year ago). It seems broken now?
Mike
@MFI-Net @MikeTheTux
try updated build
@rubensanty any update? Does that build fixes your issue?
@DPL any update? Does that build fixes your issue?
that must be almost 2yr ago. Initially, when only Audi was supported.
The US uses the old style token flow, somewhen VW consolidated the platforms in EU, which means there is no dedicated brand tolken anymore, just access_token and id_token. I could look into this, but you need to share your credentials and support testing. Send me a PM.
still the same⊠but dont worry, i do it with a rule, dont break your head!!
i will still testing all the params!
thanks so much for your work!
Hi Markus,
I did some test and could reproduce the issue:
Not sure if it could help but maybe there are higher changes in the values required between each request to update the Item Value in OH.
If it will not help, I will send my credential by PN.
In case no update of Item Values in OH3.1 UI:
Car is charging with low Power (1,3 KW)
- no big changes of reportet Values from VW-Server between the requests
eg. cruisingRangeElectric_km changes only by 1 each request/15min (256,257,258)
currentSOC_pct only change by 1 after three requests
In case of regular Item Value updates
Car is charging with min. 3,6 KW
- differences between reportet Values from VW-Server are higher
the follow error are not effect the result.
âerrorâ: { âlvBatteryStatusâ: { âcodeâ: 4112,
âmessageâ: âThe capability for the requested operation is missingâ, âgroupâ: 2,
âinfoâ: âInternal error, please try again later. If the problem persists, please contact our support.â }
Kind regrads
Juergen
yes, thanks !!!
I was running the binding (previous Build from Oct 4) with a Cupra (Seat) Formentor. Everything was working fine so far except the climater control. When I turn on the item, I get the following error:
12:40:24.186 [DEBUG] [car.internal.handler.ThingBaseHandler] - VSSXXXXXXXXXX0123: Channel climater received command ON
12:40:24.195 [DEBUG] [ctedcar.internal.api.carnet.CarNetApi] - VSSXXXXXXXXXX0123: Sending action request for rclima_v1.P_START_CLIMA_EL, reqSecToken=false, contentType=application/vnd.vwg.mbb.ClimaterAction_v1_0_2+json
12:40:24.207 [DEBUG] [nnectedcar.internal.api.ApiHttpClient] - VSSXXXXXXXXXX0123: HTTP POST https://fal-3a.prd.eu.dp.vwg-connect.com/fs-car/bs/climatisation/v1/VW/ES/vehicles/VSSXXXXXXXXXX0123/climater/actions
12:40:24.215 [TRACE] [nnectedcar.internal.api.ApiHttpClient] - Headers:
Accept-Encoding: gzip
User-Agent: okhttp/3.11.0
X-App-Name: SEATConnect
X-App-Version: 1.1.29
Content-Type: application/vnd.vwg.mbb.ClimaterAction_v1_0_2+json
Accept: application/json, application/vnd.vwg.mbb.ChargerAction_v1_0_0+xml,application/vnd.volkswagenag.com-error-v1+xml,application/vnd.vwg.mbb.genericError_v1_0_2+xml,application/vnd.vwg.mbb.RemoteStandheizung_v2_0_0+xml,application/vnd.vwg.mbb.genericError_v1_0_2+xml,application/vnd.vwg.mbb.RemoteLockUnlock_v1_0_0+xml,application/vnd.vwg.mbb.operationList_v3_0_2+xml,application/vnd.vwg.mbb.genericError_v1_0_2+xml,*/*
Accept-Charset: UTF-8
Authorization: Bearer eyJraWQiOiJNQkIwMSIsImFsZyI6IlJTMjU2In0.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.Dk4NuzlMf3zSuVXfQ7L33WLBFn1GM05y45xfWGldECHuRwBjwGUQBnvcAhOT4VQwDrHIuWdtMCfydR46ODoYwm8OR-w64fe10qKT2ZpzwI5XHvVJLVChw-Wh-w38ZFbGnRWXiyQD--syWZBal0oI1sCfjlnM2L9oLHAS44ywWgz9OfDZOaQLx6LWasuQ3vVhZL1NFahCMAfU5IKu8DBBcERNO9LGeO__AHlr4zQO_hx-kZJWjlnIpDy0pTOVSFHwhDLgIZpR_WM6JPUduI1QGduBV0zwF8qYWZykDLhNsOsXNW96BPURVpce9E3YreAUrQzEKC-5X3a4Hn_w2YiRPg
Host: msg.volkswagen.de
Content-Length: 134
12:40:24.228 [TRACE] [nnectedcar.internal.api.ApiHttpClient] - Body/Data: {"action": {"settings": {"climatisationWithoutHVpower": "without_hv_power", "heaterSource": "electric"}, "type": "startClimatisation"}
12:40:24.313 [DEBUG] [nnectedcar.internal.api.ApiHttpClient] - VSSXXXXXXXXXX0123: HTTP 400 Response: {"error":{"errorCode":"gw.error.validation","description":"Invalid payload"}}
12:40:24.321 [TRACE] [nnectedcar.internal.api.ApiHttpClient] - Headers:
X-FS-Tracking-ID: eab3c0cf-3dff-4faf-844e-9938c35cbfd3
X-FS-Error-Code: GW400
Content-Type: application/json
Content-Length: 77
Date: Tue, 26 Oct 2021 10:40:01 GMT
Connection: close
Server: www
12:40:24.330 [INFO ] [car.internal.handler.ThingBaseHandler] - VSSXXXXXXXXXX0123: Status from service rclima_v1.P_START_CLIMA_EL: API call failed POST https://fal-3a.prd.eu.dp.vwg-connect.com/fs-car/bs/climatisation/v1/VW/ES/vehicles/VSSZZZKMZNR000123/climater/actions (HTTP 400 Bad Request), result = {"error":{"errorCode":"gw.error.validation","description":"Invalid payload"}}
12:40:24.341 [DEBUG] [internal.handler.CarNetVehicleHandler] - VSSXXXXXXXXXX0123: Action startClimater submitted, initial status=rejected
Then I updated the binding to the latest build from yesterday, but now I cannot even connect to the Car Thing:
13:36:48.729 [WARN ] [car.internal.handler.ThingBaseHandler] - VSSXXXXXXXXXX0123: General Error: class org.openhab.core.library.types.QuantityType cannot be cast to class org.openhab.core.library.types.DecimalType (org.openhab.core.library.types.QuantityType and org.openhab.core.library.types.DecimalType are in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @2e4ea2)
java.lang.ClassCastException: class org.openhab.core.library.types.QuantityType cannot be cast to class org.openhab.core.library.types.DecimalType (org.openhab.core.library.types.QuantityType and org.openhab.core.library.types.DecimalType are in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @2e4ea2)
at org.openhab.binding.connectedcar.internal.api.carnet.CarNetServiceStatus.serviceUpdate(CarNetServiceStatus.java:177) ~[?:?]
at org.openhab.binding.connectedcar.internal.api.ApiBaseService.update(ApiBaseService.java:88) ~[?:?]
at org.openhab.binding.connectedcar.internal.handler.ThingBaseHandler.updateVehicleStatus(ThingBaseHandler.java:456) ~[?:?]
at org.openhab.binding.connectedcar.internal.handler.ThingBaseHandler.lambda$1(ThingBaseHandler.java:400) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
13:36:48.816 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'connectedcar:cnvehicle:CupraBridge:VSSXXXXXXXXXX0123' changed from UNKNOWN: Initializing to OFFLINE (COMMUNICATION_ERROR): General Error: class org.openhab.core.library.types.QuantityType cannot be cast to class org.openhab.core.library.types.DecimalType (org.openhab.core.library.types.QuantityType and org.openhab.core.library.types.DecimalType are in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @2e4ea2)
I removed the old things, shut down OH, deleted the build, then cleared the OH cache, copied the new build and started OH again.
Have I done something wrong?
@markus7017
Tested the new build and the problem with dynamic state options seems to be fixed (luckily the connected car binding got initialised BEFORE the other ones), so that looks fine!
Is there someone with a PEHV and electric pre heater? For me it seems not to work (AUDI/VW CarNet).
I guess :control#climater should do the job but it doesnât at least for me. But control#targetTemperature seems to work because it shows me the current temperature setup in the app.
Turn on climater used to work fine for me with an older release. But now I get an âinvalid payloadâ error in my logs. Do you have an error as well @chr1s ?
Yes! Custom bindings are not shown in the UI. Just go to the things menu and click on the blue plus to add your car.
Thanks a lot. It is working.
Did you tried to adjust the APi format under thing settings, advabced?
is there somehow an autoupdate of the values ? I try to use for my openwb to set the SOC Value.
So it must be update ~5min and send the value to the openwb.
I used to set that to a specific value indeed (I think 2). But now I donât see any field for API format anymore in 3.2.0 Snapshot release. (I am clicking open âshow advancedâ for the thing tab and I do see other settings)
