The ConnectedCar Details View Widget is the second part of the widget series for the ConnectedCar binding. It can only be used in combination with the dashboard widget.
To keep configuration simple, the predefined channel names of the binding are used. You should create a car equipement under your model and add all (check advanced) channels as points with predefined names.
Config
Config is passed over from the dashboard Widget
Screenshots
Changelog
Version 0.1
- initial release
Resources
uid: ConnectedCarDetailsView
tags: []
props:
parameters:
- description: ConnectedCarDetailsView Widget V0.1
required: false
- description: Label
label: Label (optional)
required: false
type: TEXT
- context: item
description: Name of Car Group Item
label: Car Group (mandatory)
required: true
type: TEXT
- description: prefix for item names.
label: Item prefix (mandatory)
required: true
type: TEXT
- description: Picture
label: Picture URL (optional)
required: false
type: TEXT
parameterGroups: []
# timestamp: Jul 2, 2021, 2:51:07 PM
component: f7-card
expandable: false
swipeToClose: true
style:
--f7-theme-color: var(--f7-text-color)
background-color: "=themeOptions.dark === 'light' ? 'white' : 'black'"
slots:
default:
- component: f7-card-content
slots:
default:
- component: f7-block
slots:
default:
- component: oh-image
visible: "=(!props.pictureUrl) ? false : true"
url: =props.pictureUrl
style:
width: 100%
object-fit: cover
- component: f7-swiper
visible: "=(!props.pictureUrl) ? true : false"
navigation: true
watchOverflow: true
autoHeight: true
centeredSlides: true
centerInsufficientSlides: true
init: true
class:
- padding-top
- padding-bottom
params:
initialSlide: 0
observer: true
observeSlideChildren: true
updateOnWindowResize: true
mousewheel: true
keyboard: true
slidesPerView: 1
style:
--swiper-navigation-size: 20px
--swiper-navigation-color: gray
slots:
default:
- component: f7-swiper-slide
slots:
default:
url: =items[(props.itemPrefix + "_pictures_ImageUrl1")].state
style:
width: 100%
align: center
visible: true
slots:
default:
url: =items[(props.itemPrefix + "_pictures_ImageUrl2")].state
style:
width: 100%
align: center
visible: true
slots:
default:
url: =items[(props.itemPrefix + "_pictures_ImageUrl3")].state
style:
width: 100%
object-fit: cover
visible: true
slots:
default:
url: =items[(props.itemPrefix + "_pictures_ImageUrl4")].state
style:
width: 100%
object-fit: cover
visible: true
slots:
default:
url: =items[(props.itemPrefix + "_pictures_ImageUrl5")].state
style:
width: 100%
object-fit: cover
visible: true
slots:
default:
url: =items[(props.itemPrefix + "_pictures_ImageUrl6")].state
style:
width: 100%
object-fit: cover
visible: false
slots:
default:
url: =items[(props.itemPrefix + "_pictures_ImageUrl7")].state
style:
width: 100%
object-fit: cover
init: true
class:
- padding-top
- padding-bottom
params:
initialSlide: 0
observer: true
mousewheel: true
keyboard: true
slidesPerView: 3
style:
slots:
default:
slots:
default:
- component: oh-button
text: Status
active: =!vars.tab || vars.tab === 'status'
action: variable
actionVariable: tab
actionVariableValue: status
style:
--f7-button-bg-color: orange
--f7-button-hover-bg-color: "=themeOptions.dark === 'light' ? 'white' : 'black'"
--f7-button-pressed-bg-color: "=themeOptions.dark === 'light' ? 'white' : 'black'"
slots:
default:
text: Control
active: =vars.tab === 'control'
action: variable
actionVariable: tab
actionVariableValue: control
style:
slots:
default:
text: Maintenance
active: =vars.tab === 'maintenance'
action: variable
actionVariable: tab
actionVariableValue: maintenance
style:
slots:
default:
text: Location
active: =vars.tab === 'location'
action: variable
actionVariable: tab
actionVariableValue: location
style:
slots:
default:
text: Range
active: =vars.tab === 'range'
action: variable
actionVariable: tab
actionVariableValue: range
style:
slots:
default:
text: Doors
active: =vars.tab === 'doors'
action: variable
actionVariable: tab
actionVariableValue: doors
style:
slots:
default:
text: Windows
active: =vars.tab === 'windows'
action: variable
actionVariable: tab
actionVariableValue: windows
style:
slots:
default:
text: Tires
active: =vars.tab === 'tires'
action: variable
actionVariable: tab
actionVariableValue: tires
style:
slots:
default:
text: Trip Short
active: =vars.tab === 'tripShort'
action: variable
actionVariable: tab
actionVariableValue: tripShort
style:
slots:
default:
text: Trip Long
active: =vars.tab === 'tripLong'
action: variable
actionVariable: tab
actionVariableValue: tripLong
style:
slots:
default:
text: RLU History
active: =vars.tab === 'rluHistory'
action: variable
actionVariable: tab
actionVariableValue: rluHistory
style:
slots:
default:
text: Geofence Alerts
active: =vars.tab === 'geofenceAlerts'
action: variable
actionVariable: tab
actionVariableValue: geofenceAlerts
style:
slots:
default:
text: Speed Alerts
active: =vars.tab === 'speedAlerts'
action: variable
actionVariable: tab
actionVariableValue: speedAlerts
style:
slots:
default:
text: Information
active: =vars.tab === 'information'
action: variable
actionVariable: tab
actionVariableValue: information
style:
- component: oh-list
class:
- padding
slots:
default:
- component: oh-repeater
visible: =(!vars.tab) || vars.tab === 'status'
for: item
sourceType: itemsInGroup
groupItem: =props.carGroup
filter: loop.item.label.includes("status_") == true
slots:
default:
- component: oh-list-item
title: =loop.item.name.split("_")[2]
badge: =items[loop.item.name].displayState || items[loop.item.name].state
visible: =vars.tab === 'control'
for: item
filter: loop.item.label.includes("control") == true
slots:
default:
- component: oh-toggle-item
item: =loop.item.name
color: '=(items[loop.item.name].state == "ON") ? "yellow" : "gray"'
visible: =vars.tab === 'maintenance'
for: item
filter: loop.item.label.includes("maintenance_") == true
slots:
default:
visible: =vars.tab === 'location'
for: item
filter: loop.item.label.includes("location_") == true
slots:
default:
visible: =vars.tab === 'range'
for: item
filter: loop.item.label.includes("range_") == true
slots:
default:
visible: '=(((items[(props.itemPrefix + "_range_SecondaryFuelType")].state == 0) && (loop.item.label.includes("Secondary") == true)) || (items[loop.item.name].state === "UNDEF") ) ? "false" : "true"'
visible: =vars.tab === 'doors'
for: item
filter: loop.item.label.includes("doors_") == true
slots:
default:
icon: '=themeOptions.dark === "light" ? "oh:car_door" : "oh:car_door_white" '
badge: =items[loop.item.name].state
badgeColor: '=(items[loop.item.name].state === "CLOSED") ? "green" : "red" '
visible: =vars.tab === 'windows'
for: item
filter: loop.item.label.includes("windows_") == true
slots:
default:
badgeColor: '=(items[loop.item.name].state === "CLOSED") ? "green" : (items[loop.item.name].state === "OPEN") ? "red" : "gray"'
visible: =vars.tab === 'tires'
for: item
filter: loop.item.label.includes("tires_") == true
slots:
default:
icon: '=themeOptions.dark === "light" ? "oh:car_tire_alert" : "oh:car_tire_alert_white" '
badge: '=(items[loop.item.name].state === "ON") ? "GOOD" : "BAD" '
badgeColor: '=(items[loop.item.name].state == "ON") ? "green" : "red" '
visible: =vars.tab === 'tripShort'
for: item
filter: loop.item.label.includes("tripShort") == true
slots:
default:
title: =loop.item.name.split("_")[1] + " " + loop.item.name.split("_")[2]
visible: =vars.tab === 'tripLong'
for: item
filter: loop.item.label.includes("tripLong") == true
slots:
default:
visible: =vars.tab === 'rluHistory'
for: item
filter: loop.item.label.includes("rluHistory") == true
slots:
default:
visible: =vars.tab === 'geofenceAlerts'
for: item
filter: loop.item.label.includes("geoFenceAlerts") == true
slots:
default:
visible: =vars.tab === 'speedAlerts'
for: item
filter: loop.item.label.includes("speedAlerts") == true
slots:
default:
visible: =vars.tab === 'information'
for: item
filter: loop.item.label.includes("general_") == true
slots:
default:
