Hello all, is this tread still alive?
I’ve get tis error.
2020-12-28 12:59:55.789 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert '{
Somebody know’s what’s wrong?
Thanks,
Harold.
I’ve get tis error.
Thanks,
Harold.
Hello Roger, how do you create a new user in Sems Portal?
Can you help me?
Cheers,
Harold
Hi Harold,
You can make a new user in Sems Portal. Select the tab “Management”, select your device and ad a visitor.
Dit you ad your script to the Whitelist?
Succes,
Toine
Hello Toine,
What do you mean with whitelist?
Just add a visitor, but now i’ve got the error
2020-12-28 20:57:19.568 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert '{
“hasError”: false,
“code”: 0,
“msg”: “Success”,
“data”: {
"agreement_agreement": true
“components”: {
"para": null,
"langVer": 91,
"timeSpan": 0,
"api": "http://eu.semsportal.com:82/api/Auth/GetTokenV2",
"msgSocketAdr": "https://eu-xxzx.semsportal.com"
“api”: “https://eu.semsportal.com/api/”
}’ to a state type which item ‘UG_PV_SoC’ accepts: [DecimalType, QuantityType, UnDefType].
Helaas,
Harold.
Hi Harold,
You seem to have a similar problem as Toine previously. You need to login to the semsportal with the newly created account at least once for it to work. Let me know if this helped.
Best Regards
RogerG
Oke logged in and i had to confirm it.
Now i don’t see anything in the log. Maybe that’s a good signs???
Edit: made a new semsapi.sh with the right email-passwd and numbers.
Now i get
Cannot convert '/etc/openhab2/scripts/semsapi.sh: line 5: jq: command not found
in the log.
And how to put it in the sitemap?
Something like?, Text item=Energy UG_PV_Total_Output
Actually, you should see the portal responses in the log …
If you add
Text item=UG_PV_Todays_Output Text item=UG_PV_Output_Power Text item=UG_PV_Grid Text item=UG_PV_Loadstatus Text item=UG_PV_Home_Load Text item=UG_PV_SoC Text item=UG_PV_Battery Text item=UG_PV_Batterystatus
to the sitemap, we can maybe find out more. openhab should get new values every minute from the portal.
Did that in the sitemap, but then i’ve got a error.
Maybe because there is still something wrong.
See one reply up.
When i use the samsapi.sh of topic starter then i get,
2020-12-29 12:21:15.660 [WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert '{
“hasError”: false,
“code”: 0,
“msg”: “Success”,
“data”: {
"uid": " ",
"timestamp": 1609240875653,
"token": " ",
"client": "ios",
"version": "v2.1.0",
"language": "en"
“components”: {
"para": null,
"langVer": 91,
"timeSpan": 0,
There is still something wrong. I copied all of topic starter.
Looks like you don’t have jq installed (this is a simple JSON parser). I thought it was a default package with all Linux distributions. On what platform are you running openhab?. If it is raspbian/openhabian, ubuntu or Debian you should be able to install jq with
sudo apt-get update
sudo apt-get install jq
Can you also try just running the shell script on command line and see what it returns there?
raspbian, try sudo apt-get install jq
Edit: Nope, no joy.
echo “$RETURN” | jq “.data”
null
I’m a bit lost here … Could you replace in the bash-script
with
echo “$RETURN”
and just run the script on command line again. Hopefully that output will help to debug.
echo “$RETURN” gives
“hasError”: false,
“code”: 100003,
“msg”: “missing parameter.”,
“data”: null,
“components”: {
“para”: null,
“langVer”: 91,
“timeSpan”: 0,
“api”: “000”,
“msgSocketAdr”: “”
Mmmh. It seems that the authentication to the semsportal fails.
Could you add
echo $RESULT
echo $HEADER
to end of the script.
EDIT: Please X-out any sensitive data in the output before posting, such as the token or your id and email.
Oeps, my mistake, hope i wiped it all.
Put
echo $RESULT
echo $HEADER
at the end.
Now nothing happens in the log file.
But in the exec.things, i don’t see collors like the topic starter.
Is that oke?
Could you run the script on the command line with those additions?
No then i get > something
Then i use ctrl c to stop it.
But no nothing happens in the log about the goodwe.
Roger,
Now i’have a very very long logfile.
Still a mistake in the sitemap, but we’re getting there.
Edit: It’s working,but how can i shorten the logfile?
