markymark
(Mark Baumann)
March 5, 2020, 4:01pm
1
Hello I have set up the Mail Binding like in the the docs described.
I have now struggle with the error
`2020-03-05 16:00:13.971 [INFO ] [inding.mail.internal.POP3IMAPHandler] - error when trying to refresh IMAP: Connection dropped by server?`
I am using Gmail. Maybe someone know how to solve it?
Thank you.
Mark Baumann
markymark
(Mark Baumann)
March 5, 2020, 4:16pm
2
I have already IMAP activated in the Gmail Settings.
namraccr
(namraccr)
March 31, 2020, 1:30am
4
No one has yet provided their configuration details. Not much chance anyone can help without those…
@Carmine_Di_Biase @markymark
You are definitely right. That’s my things file:
Thing mail:smtp:googlesmtp [ hostname="smtp.gmail.com", port="587", from="xxxxxx@gmail.com", sender="xxxxxx@gmail.com", security="TLS", username="xxxxxx", password="xxxxxx" ]
Thing mail:imap:googleimap [ hostname="imap.gmail.com", port="993", security="SSL", username="xxxxxx", password="xxxxxx" ] {
Channels:
Type mailcount : inbox_total [ folder="INBOX", type="TOTAL" ]
Type mailcount : inbox_unread [ folder="INBOX", type="UNREAD" ]
I’ve no problem in sending mail; in paper ui panel the imap seems to be online, but on the log file I see the error above.
I tried putting the email account password, the two-factor authentication password and I also tried putting a wrong password and I get always the same error
namraccr
(namraccr)
March 31, 2020, 12:50pm
6
Make sure you’ve enabled “less secure app access” in your google settings. Per their docs:
Because less secure apps can make your account more vulnerable, Google will automatically turn this setting off if it’s not being used.
I’ve tried, but doesn’t solve the problem
markymark
(Mark Baumann)
March 31, 2020, 8:24pm
8
Does someone has this binding and it works?
namraccr
(namraccr)
April 1, 2020, 12:41am
9
I’ve seen some references indicate that the protocol needs to be imaps
instead of imap
. In which case the binding may need an update to allow for that in the thing definition.
CHTHSCH
(Thomas Schmidt)
April 1, 2020, 11:59am
10
I have the same problem with:
Bluewin Mail provided by Swisscom
Outlook Mail
iCloud Mail
For iCloud I generated an application specific password.
For all of these accounts I get a warning as described here https://community.openhab.org/t/problem-refreshing-imap-pop3/95637?u=chthsch
Does anyone have a solution for this problem?
I have enabled DEBUG mode, but do not get any additional entry in the log files.
