I have a running openhab instance with the KNX 2.0 binding. But I’m still getting error logs:
2019-10-29 19:54:00.492 [ERROR] [et/IP Tunneling 192.168.100.105:3671] - establishing connection failed, timeout connecting to control endpoint /192.168.100.105:3671
This was my old IP address. I changed it to my new one. openhab is estblishing a connection to my new IP address and everything looks like it is runnig.But I still receive this logs.
I changed my IP address in the knx.things file:
Bridge knx:ip:bridge [
type=“TUNNEL”,
ipAddress=“192.168.100.10”,
portNumber=3671,
localIp=“192.168.100.22”,
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=60,
localSourceAddr=“0.0.0”
It’s been awhile since I’ve had issues with other bindings that I have defined a thing file for; but have you tried moving your thing file out of the directory and issuing a clear things (not sure of exact karaf command) in karaf, restarting OH and then dropping your thing file back in place?
Try logging into the Karaf console and clear the things with an empty things folder, and then move your things back after a restart and lack of logging about the bad IP.
