I have seen all previous posts about this and tried everything but nothing seems to have worked.
When openhab is starting it fails to connect to my RFXCOM and I get the following log message…
2016-05-02 16:56:51.948 [INFO ] [.b.r.internal.RFXComConnection] - Connecting to RFXCOM [serialPort='/dev/ttyUSB0' ].
2016-05-02 16:56:52.048 [ERROR] [.b.r.internal.RFXComConnection] - Connection to RFXCOM controller failed.
gnu.io.NoSuchPortException: null
at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273) ~[na:na]
at org.openhab.binding.rfxcom.internal.connector.RFXComSerialConnector.connect(RFXComSerialConnector.java:60) ~[na:na]
at org.openhab.binding.rfxcom.internal.RFXComConnection.connect(RFXComConnection.java:118) ~[na:na]
at org.openhab.binding.rfxcom.internal.RFXComConnection.updated(RFXComConnection.java:103) ~[na:na]
My config…
################################ RFXCOM Binding #######################################
# Serial port of RFXCOM interface
# Valid values are e.g. COM1 for Windows and /dev/ttyS0 or /dev/ttyUSB0 for Linux
rfxcom:serialPort = /dev/ttyUSB0
# Set mode command for controller (optional)
# E.g. rfxcom:setMode=0D000000035300000C2F00000000
#rfxcom:setMode =
Start Script…
#!/bin/sh
cd `dirname $0`
# set path to eclipse folder. If local folder, use '.'; otherwise, use /path/to/eclipse/
eclipsehome="server";
# set ports for HTTP(S) server
HTTP_PORT=8080
HTTPS_PORT=8443
DAEMON_USER=root
DAEMON_NAME=openhab
# get path to equinox jar inside $eclipsehome folder
cp=$(find $eclipsehome -name "org.eclipse.equinox.launcher_*.jar" | sort | tail -1);
echo Launching the openHAB runtime...
java \
-Dosgi.clean=true \
-Declipse.ignoreApp=true \
-Dosgi.noShutdown=true \
-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 \
-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 \
-Djetty.port=$HTTP_PORT \
-Djetty.port.ssl=$HTTPS_PORT \
-Djetty.home=. \
-Dlogback.configurationFile=configurations/logback.xml \
-Dfelix.fileinstall.dir=addons -Dfelix.fileinstall.filter=.*\\.jar \
-Djava.library.path=lib \
-Djava.security.auth.login.config=./etc/login.conf \
-Dorg.quartz.properties=./etc/quartz.properties \
-Dequinox.ds.block_timeout=240000 \
-Dequinox.scr.waitTimeOnBlock=60000 \
-Dfelix.fileinstall.active.level=4 \
-Djava.awt.headless=true \
-jar $cp $* \
-console
I have also tried creating a SYMLINK which doesnt work either. I simply get the same connection failed message.
