I’m doing a fresh openHABian install on a RPi4. I have Tesla binding running on a previous install but I’m unable to get console to cooperate this time.
I SSH into my RPi4, open console using “ssh -p 8101 openhab@localhost”
I then issue command “smarthome:tesla login” but when I go to enter my username, some of the characters drop.
I had this happen before and I was able to find a workaround but I forgot what that was.
I’ve had the same issue - even copying the strings to the console wasn’t working!
In the end I gave up and just used the setup directly in Paper-UI - this was working in the end for me.
Thank you for the response…that means I’ll have to look deeper into the instructions for the PaperUI setup. I didn’t have success at first try.
Edit: I got it working. I made the mistake of making it more complicated than it needed to be. That’s a nice thing about a fresh install…you can fix previous mistakes.
