I am still running OH 2.5 for device compatibility, OH is running fine, and I can access sitemaps locally
and remotely via OH Cloud.
Since I have changed my router, I can see the traffic per device more clearly and I found out that my OH server is constantly uploading some SSL traffic. Then I consulted the iftop on the Linux where OH runs and it became clear that the trafiic is going to Linode server, which seems to be OH Cloud. I verified that by disabling remote access in Paper UI services and the traffic stops.
So I thought someone must be viewing the sitemap on the app or in the browser, as when I open the app the traffic is up to 4Mb/s because the sitemap has a live camera feed on the first page. But a few days ago when I messed with disabling remote access, I tested that when I close the app, the traffic goes down to about 50b/s.
Then I thought I already fixed the issue as when I disabled Voice Assistants in the OH cloud, traffic also stopped, but only temporarily, today I noticed the traffic again, and nobody I know is using remote access now.
I am still unsure what is the cause, is it my sitemap that I know has some formatting errors(but is hard to find all errors as it has 3000 lines, tho it still works), is that causing errors on OH cloud and retransmitting traffic even when nobody watches it.
I also have a similar setup on Raspberry in our weekend loghouse, it also works fine, but it has traffic, when no one is accessing it. It has no live camera feed on sitemap tho, but it has some camera snapshots that refresh every 5s. The difference is that there I am running OH3.
Any suggestions appreciated, on what info I still need to share to give insights into the problem.
I understand that OH 2 is officially not supported, but I suspect that oh cloud shouldn’t be calling for data for no reason even if OH2 is the server.
Is it possible that some bot guessed my OH passwords and is constantly analyzing my data and camera feed, should I change all 5 passwords for all the users, it is tedious tho.
Is there a way to see on the OH cloud, who is using it to access my OH server?
Been using OH for over 3 years now, but still need to learn how it has to be configured so it works properly
Thanks,
Matej
