rayb
( Ralf Berhorst)
July 5, 2022, 10:52am
8
Hi Markus, yes I try to use it. But it does not support all required values I expect. I create a request for it (my first one ). But I have now idea if or when somebody check that :
opened 08:05AM - 21 May 22 UTC
enhancement
My environment:
- openHAB 3.3.0.M5
- Pi 4 with Debian 11.3
- openjdk versio… n "11.0.15" 2022-04-19
- Stieble Eltron WPF-07
- ISG plus 12.2.1.222 (currently the latest version)
I plan to use the binding to control the "heat pump" depend on the power of my „photovoltaic“ solution. Therefore I need the „Energy Management“ information/control. In deed, the cooling information does not belong to energy management, but I miss them too.
I add a link from Stieble ELTRON with more technical details of the modbus TCP extension of the ISG. Furthermore a txt file (isg.txt), which is a snapshot of my ISG web page and some screen shots ;-)
INFO - SYSTEM - COOLING
"ACTUAL TEMPERATURE AREA"
"SET TEMPERATURE AREA"
INFO - SYSTEM - SOURCE
"SOURCE TEMPERATURE"
"SOURCE PRESSURE"
INFO - HEAT PUMP
"VD COOLING"
SETTINGS - COOLING
„COOLING“
SETTINGS - ENERGY MANAGMENT
"SG READY ENABLED"
"SG READY INPUT“
"Heating Buffer“
"UPPER ROMM/BUFFER TEMP. HC1“
"UPEER SET DHW TEMP."
https://www.stiebel-eltron.de/content/dam/ste/cdbassets/current/bedienungs-_u_installationsanleitungen/modbus_tcp_ip_installationmanual_doc-00067760.pdf
[ISG.txt](https://github.com/openhab/openhab-addons/files/8747211/ISG.txt)
<img width="733" alt="settings-cooling" src="https://user-images.githubusercontent.com/87530087/169642495-96e71559-5a62-4b11-9949-dc813785f5bb.png">
<img width="726" alt="info-heatpump" src="https://user-images.githubusercontent.com/87530087/169642499-dea56ea7-595b-45ae-b58c-a6042a34977d.png">
<img width="529" alt="info-system" src="https://user-images.githubusercontent.com/87530087/169642500-d3562266-794c-4bc5-8edd-90d84a090b65.png">
<img width="722" alt="settings-energymanagement" src="https://user-images.githubusercontent.com/87530087/169642501-ac89ed59-f4ae-4337-8e36-21c413e345ac.png">
We will see.
Best Regards
Ralf
