Hi all,
LG recently changed its login API. Because of that, new LG ThinQ bridges cannot log in anymore. The same happens to existing bridges as soon as they need a fresh login, for example after a configuration change. Bridges that are already online keep working for now.
I’ve submitted the fix, plus several device fixes, to the official repository. Until the maintainers review and merge it, you can use the test builds below.
What’s fixed
- Bridge login: works again after LG’s API change (#22163, PR #22164).
- Dishwasher (#19726):
- the Thing no longer fails on start;
- binary data is decoded correctly;
powerfollows the real state;door-lockis filled.
- ThinQ V1 devices: a Thing no longer goes OFFLINE with “Exhausted trying to get monitor data” when the device sends no data for a while.
- Washer/dryer:
process-statenow shows the running process;- a new
previous-statechannel is added automatically to existing Things; - state labels are fixed.
- Air conditioner: auto-dry state and command are fixed.
- Heat pump: ThinQ V1 heat pumps no longer fail when their capabilities are loaded.
- United Kingdom: the country is now sent as
GBinstead ofUK, which LG rejected. Existing configurations are converted automatically. - Connections: more robust TLS handshake with some LG servers.
The full list is in PR #22165.
Which file to download
All files are at GitHub - nemerdaud/openhab-thinq-stuff: Some distribution binary, files and docs. · GitHub. They contain the same fixes, built for each openHAB line:
| Your openHAB version | Download |
| 5.2.x (current stable) and 5.3.0.M1–M3 | org.openhab.binding.lgthinq-5.2.4-SNAPSHOT.jar |
| 5.3.0 snapshots built after 28 Oct 2026 | org.openhab.binding.lgthinq-5.3.0-SNAPSHOT.jar |
| 5.1.x | org.openhab.binding.lgthinq-5.1.5-SNAPSHOT.jar |
If you are not sure, check Help & About in the UI and use the 5.2.4 file if your version is 5.2.x or a 5.3 milestone. Ignore the older JARs in that repository.
How to install
Uninstall the official binding, if it is installed: Settings → Add-ons → LG ThinQ → Uninstall. Your Bridge, Things and Items are kept; they will be offline until the new JAR is loaded.
Copy the JAR into the
addonsfolder:- openHABian / apt / rpm:
/usr/share/openhab/addons/ - Docker: the volume mapped to
/openhab/addons - manual installation:
<openHAB folder>/addons/
Wait a minute and check that the bundle is active. In the Karaf console (
openhab-cli console) run:bundle:list | grep -i thinqThe state should be
Active. -
If your bridge was offline because of the login problem, disable and re-enable the Bridge. If it still fails, delete and recreate it. Your Things and Items stay as they are.
To go back: delete the JAR from
addonsand reinstall the official binding.
The 5.1 file was built and unit tested, but I could not test it on a running 5.1 system.
Feedback
Please report your results here or in the issues above. Tell me your openHAB version, device type and model, and whether it is ThinQ V1 or V2. If something goes wrong, a TRACE log helps a lot:
log:set TRACE org.openhab.binding.lgthinq
You can turn it back off with log:set INFO org.openhab.binding.lgthinq.
Thanks to everyone who reported problems and sent logs!
