Is it possible to control devices like hue or tredfi which are conected to new echo plus with openhab?
Or do I need a separate gateway for this?
thanks
thanks
At the Moment, i think it is not possible! I use also a Echo Plus and connected two bulbs from Hue, but i don’t find any way to make them in OH2 available.
BR
Dennis
yes same problem here the hue binding dont reconizes echo plus as an hub
what do i do now buy and phillips bridge or will there be an update maybe would be cool if someone knows something
maybe I write an email to amazon.
today it is not possible, maybe someday?
perhaps they have an answer to this question
maybe you can use IFTT as an workaround,
but you would end up in a very bad performance
in terms of trigger and perform an action
