Hey Peoples,
setup my openhabianpi with mosquitto broker, completed the test and all works fine.
Using the org.openhab.binding.yeelight-2.1.0 I set up a *.items file in /etc/openhab2/items with following content:
Dimmer Yeelight_1_Neu_Brightness "Yeelight_1_Neu_Brightness" {channel=" yeelight:Wonder:0x0000000003708d4c:Brightness", mqtt="<[broker:Yeelight_1_Neu_Brightness:state:default], >[broker:Yeelight_1_Neu_Brightness:command:*:default]"}
Now if i send a message to the topic the slider of the dimmer changes in openhab to the value i send in the messafe data. The problem is the value of the yeelight does nothing. Brightness is the same value as before.
Log is as following when i move the slider in the paper ui:
2018-06-11 11:52:35.895 [ome.event.ItemCommandEvent] - Item 'Yeelight_1_Neu_Brightness' received command 51
2018-06-11 11:52:35.898 [INFO ] [yeelight.handler.YeelightHandlerBase] - YeelightColorHandler: command: 51
2018-06-11 11:52:35.913 [vent.ItemStateChangedEvent] - Yeelight_1_Neu_Brightness changed from 71 to 51
but when I Send the message via mqtt it only shows:
2018-06-11 12:56:00.229 [vent.ItemStateChangedEvent] - Yeelight_1_Neu_Brightness changed from 50 to 20
So my question is to become the behavior that I want:
Openhab Listen to mqtt messages and communicate to the smart bulb if it have to change a state.
If it works I want also Color and ColorTemperature to set up.
Thanks for your help!
