Hi Guys,
i want to control my OH KNX Items with Snips.
To use MQTT is a Workaround for me, hard to expand and maintain.
Now i found a Snips App from Paule https://gitlab.com/faupau/snips-lichtsteuerung-openhab-skill
This could be easy to expand and i possibly don´t need so much rules.
It is working great, but changes only my OH Items state and triggers not the item channel.
So the items change in OH but not on KNX, which is possibe with curl on the snips CLI.
I am not the Rest best is there a possibility to change the python script and change also the channel state, or do i have to make a rule for each item?
Here is the script for switching on:
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import configparser
from hermes_python.hermes import Hermes
from hermes_python.ffi.utils import MqttOptions
from hermes_python.ontology import *
import requests
import io
import json
translation_table = { #translation table to replace german umlauts
"ä": "ae",
"ö": "oe",
"ü": "ue",
"Ü": "Ue",
"Ö": "Oe",
"Ä": "Ae"
CONFIGURATION_ENCODING_FORMAT = "utf-8"
CONFIG_INI = "config.ini"
class SnipsConfigParser(configparser.SafeConfigParser):
def to_dict(self):
return {section : {option_name : option for option_name, option in self.items(section)} for section in self.sections()}
def read_configuration_file(configuration_file):
try:
with io.open(configuration_file, encoding=CONFIGURATION_ENCODING_FORMAT) as f:
conf_parser = SnipsConfigParser()
conf_parser.readfp(f)
return conf_parser.to_dict()
except (IOError, configparser.Error) as e:
return dict()
def subscribe_intent_callback(hermes, intentMessage):
conf = read_configuration_file(CONFIG_INI)
action_wrapper(hermes, intentMessage, conf)
def action_wrapper(hermes, intentMessage, conf):
openhab_port = conf['global'].get("openhab_server_port") #getting openhab port from config.ini
openhab_server = conf['global'].get("openhab_server_url") #getting openhab server ip from config.ini
room = intentMessage.slots.deviceLocation.first().value #gets room slot
room_without = room.translate(str.maketrans(translation_table)) #replaces german umlauts
room_item = room_without
room_item += "_light"
response = requests.get('http://{}:{}/rest/items/{}'.format(openhab_server, openhab_port, room_item))
response_string = json.loads(response.text)
item_type = response_string.get('type')
if item_type == 'Switch':
command = "ON"
elif item_type == 'Dimmer':
command = "100"
elif item_type == 'Color':
command = "0, 0, 100"
res = requests.put('http://{}:{}/rest/items/{}/state'.format(openhab_server, openhab_port, room_item), command) #sending command to openhab
if res.status_code == 202:
result_sentence = "Schalte das Licht in {} ein".format(str(room))
else:
result_sentence = "Das Eitem {} gibt es nicht. Bitte erstelle in Openhab ein Eitem mit dem Namen: {} unterstrich leiht!"
current_session_id = intentMessage.session_id
hermes.publish_end_session(current_session_id, result_sentence)
if __name__ == "__main__":
mqtt_server = conf['global'].get("mqtt_server")
mqtt_opts = MqttOptions()
with Hermes("{}:1883".format(mqtt_server)) as h:
h.subscribe_intent("Paule:LampenAnSchalten", subscribe_intent_callback) \
.start()
i hope anyone of the python/rest specialists could help me, because i think this can be the best way to control KNX Items with snips.
otherwise i have to make a rule for each state Change.
thx for help
Vaillan
