Syntactically its correct to write
Switch btnTest "Test" (gTestGPIO) { gpio="pin:17", gpio="pin:18" }
but the effect is only pin 18 is switched. Is there a way to switch many pins at once?
Would using a rule not come in handy here? Then you can execute 2 lines to set your 2 pins.
Hi, thanks.
Sure, a rule will manage this, but it needs 3 items and a rule…
This was more of an academic question about the intents of the item
definition implementor…
