Hi, everyone
Pretty beginner
But I’ve been running the software for half a year
I wanted to know if there is a possibility to create RULE
That
When I switch on and off a switch at a specified time twice then the other switches will be turned off or on
I have OPENHAB2 on RASPBERRY 3
And a large amount of SONOFF switches
Google translation…
Sorry…
Create a proxy (dummy switch) item and use a rule to trigger the devices on/off. I also have a few sonoff’s and use proxy items to control multiple devices.
Short example
rule "Proxy Switch"
Item Proxy_Switch received command OFF
Sonoff1.sendCommand(OFF)
Sonoff2.sendCommand(OFF)
Sonoff3.sendCommand(OFF)
What to mean by that? Could you give an example?
Well, what do you mean by “a specific time”? given items:
Switch MyTriggerSwitch "Trigger" ...
Switch MyRegularSwitch1 "Light 1" ...
Switch MyRegularSwitch2 "Light 2" ...
Switch MyRegularSwitch3 "Light 3" ...
Rule:
var Timer myTimer = null
val Number startHour = 8
val Number startMinute = 30
val Number stopHour = 14
val Number stopMinute = 45
rule "trigger"
Item MyTriggerSwitch received command
if(now.getMinuteOfDay >= (startHour * 60 + startMinute) && now.getMinuteOfDay < (stopHour * 60 + stopMinute)) {
if(myTimer === null) {
myTimer = createTimer(now.plusMillis(500), [
myTimer = null
} else {
MyRegularSwitch1.sendCommand(if(MyRegularSwitch1.state != ON) ON else OFF)
MyRegularSwitch2.sendCommand(if(MyRegularSwitch2.state != ON) ON else OFF)
MyRegularSwitch3.sendCommand(if(MyRegularSwitch3.state != ON) ON else OFF)
if I
Turn on
And turn off
Turn on
And turn off
Within five seconds
Command will exit
I do not care if it is defined as turning on or off
I mean if I press the button 4 times
Command will exit
think about it
This allows you to control several devices through one switch
Turn on the light with one click and the fan in two clicks
You could do something like trigger a rule from switch OFF.
Rule checks if a timer is running - if not, starts it running and exits.
But if the timer IS running, this is the second OFF - so now do whatever is needed.
The timer can just null itself if it gets to completion.
Just inform
I’m just using the RULE ENGINE
So I need examples
So the specific time is the time you need to push the button 4 times… even easier
var Number myCounter = 0
rule "trigger"
if(myTimer === null) { // no timer started, so startup timer
myTimer = createTimer(now.plusMillis(5000), [ // timeout is 5 Seconds
myTimer = null // when timer expired, reset timer
myCounter = 0 // and counter
myCounter += 1 // each time a command is received, count up
if(myCounter == 4) { // rule was triggered 4 times within 5 Seconds
MyRegularSwitch1.sendCommand(if(MyRegularSwitch1.state != ON) ON else OFF) // toggle Switch
MyRegularSwitch2.sendCommand(if(MyRegularSwitch2.state != ON) ON else OFF) // toggle Switch
MyRegularSwitch3.sendCommand(if(MyRegularSwitch3.state != ON) ON else OFF) // toggle Switch
Maybe toggling switches is not the goal, but then you have to decide which switch should be the “Master” (i.e. which switch state should be used to toggle)
EDIT: some additional information…
The “RULE ENGINE” is an experimental rule engine and you will not be able to achieve this level of complicated rule and logic with it. You will need to write a rule in a text file. The one that @Udo_Hartmann just posted above is brilliant!!. I would really have struggled to come up with that and it is so simple in the end!! Nice rule!!
now.plusMillis?
of course
I realized that this can not be done with a rule engine
I just stressed that I was not so experienced with writing rules
So only if you can explain to me what parts I am supposed to change in the code
And again
I have a switch that turns on a light and I want to turn it into a trigger for more lights if I press it 4 times
And yet I want him to continue to do his work, which is the lighting of the particular light
now plus 5000 milliseconds (Or in 5 seconds time from now)
Equivalent to now.plusSeconds(5)
The code that @Udo_Hartmann provided is very good and should give you a head start.
Copy it. Don’t copy and paste. Copy it, understand it. You will be able to build from that
Actually, I think a better way to say it is that we don’t know how to achieve this level of complicated Rule with it yet. I actually think it is mature enough as is to handle a Rule like this. I just couldn’t tell you how to do it.
Indeed
The only change I would make is to put the Switches in a Group and forEach over the Group.
