Hallo!
I would like to set up a simple control for my radiator thermostats in openHAB 2. This is my items/heating.items:
Group ALL
Group HEATING (ALL)
Group HEATING_LRK (HEATING)
Group HEATING_LR (HEATING_LRK)
Group HEATING_K (HEATING_LRK)
Group HEATING_B (HEATING)
Dimmer K_Heating_Dimmer "K_Heating Dimmer" <"signal-3"> (HEATING_K) {channel="zwave:device:011bc32e:node4:switch_dimmer"}
Number K_Heating_Sensor_Temperature "K_Heating Current temperature" <temperature> (HEATING_K) {channel="zwave:device:011bc32e:node4:sensor_temperature"}
Number K_Heating_Thermostat_Mode "K_Heating Thermostat mode" <line> (HEATING_K) {channel="zwave:device:011bc32e:node4:thermostat_mode"}
Number K_Heating_Setpoint_Heating "K_Heating Setpoint (heat)" <temperature> (HEATING_K) {channel="zwave:device:011bc32e:node4:thermostat_setpoint_heating"}
Number K_Heating_Setpoint_Furnace "K_Heating Setpoint (energy heat)" <temperature> (HEATING_K) {channel="zwave:device:011bc32e:node4:thermostat_setpoint_furnace"}
Switch K_Heating_Alarm_System "K_Heating Alarm (system)" <siren> (HEATING_K) {channel="zwave:device:011bc32e:node4:alarm_system"}
Switch K_Heating_Alarm_Power "K_Heating Alarm (power)" <siren> (HEATING_K) {channel="zwave:device:011bc32e:node4:alarm_power"}
Number K_Heating_Battery_Level "K_Heating Battery level" <line> (HEATING_K) {channel="zwave:device:011bc32e:node4:battery_level"}
Dimmer B_Heating_Dimmer "B_Heating Dimmer" <"signal-3"> (HEATING_H) {channel="zwave:device:011bc32e:node6:switch_dimmer"}
Number B_Heating_Sensor_Temperature "B_Heating Current temperature" <temperature> (HEATING_H) {channel="zwave:device:011bc32e:node6:sensor_temperature"}
Number B_Heating_Thermostat_Mode "B_Heating Thermostat mode" <line> (HEATING_H) {channel="zwave:device:011bc32e:node6:thermostat_mode"}
Number B_Heating_Setpoint_Heating "B_Heating Setpoint (heat)" <temperature> (HEATING_H) {channel="zwave:device:011bc32e:node6:thermostat_setpoint_heating"}
Number B_Heating_Setpoint_Furnace "B_Heating Setpoint (energy heat)" <temperature> (HEATING_H) {channel="zwave:device:011bc32e:node6:thermostat_setpoint_furnace"}
Switch B_Heating_Alarm_System "B_Heating Alarm (system)" <siren> (HEATING_H) {channel="zwave:device:011bc32e:node6:alarm_system"}
Switch B_Heating_Alarm_Power "B_Heating Alarm (power)" <siren> (HEATING_H) {channel="zwave:device:011bc32e:node6:alarm_power"}
Number B_Heating_Battery_Level "B_Heating Battery level" <line> (HEATING_H) {channel="zwave:device:011bc32e:node6:battery_level"}
Dimmer LR_Heating_Left_Dimmer "LR_Heating_Left Dimmer" <"signal-3"> (HEATING_LR) {channel="zwave:device:011bc32e:node5:switch_dimmer"}
Number LR_Heating_Left_Sensor_Temperature "LR_Heating_Left Current temperature" <temperature> (HEATING_LR) {channel="zwave:device:011bc32e:node5:sensor_temperature"}
Number LR_Heating_Left_Thermostat_Mode "LR_Heating_Left Thermostat mode" <line> (HEATING_LR) {channel="zwave:device:011bc32e:node5:thermostat_mode"}
Number LR_Heating_Left_Setpoint_Heating "LR_Heating_Left Setpoint (heat)" <temperature> (HEATING_LR) {channel="zwave:device:011bc32e:node5:thermostat_setpoint_heating"}
Number LR_Heating_Left_Setpoint_Furnace "LR_Heating_Left Setpoint (energy heat)" <temperature> (HEATING_LR) {channel="zwave:device:011bc32e:node5:thermostat_setpoint_furnace"}
Switch LR_Heating_Left_Alarm_System "LR_Heating_Left Alarm (system)" <siren> (HEATING_LR) {channel="zwave:device:011bc32e:node5:alarm_system"}
Switch LR_Heating_Left_Alarm_Power "LR_Heating_Left Alarm (power)" <siren> (HEATING_LR) {channel="zwave:device:011bc32e:node5:alarm_power"}
Number LR_Heating_Left_Battery_Level "LR_Heating_Left Battery level" <line> (HEATING_LR) {channel="zwave:device:011bc32e:node5:battery_level"}
Dimmer LR_Heating_Centre_Dimmer "LR_Heating_Centre Dimmer" <"signal-3"> (HEATING_LR) {channel="zwave:device:011bc32e:node2:switch_dimmer"}
Number LR_Heating_Centre_Sensor_Temperature "LR_Heating_Centre Current temperature" <temperature> (HEATING_LR) {channel="zwave:device:011bc32e:node2:sensor_temperature"}
Number LR_Heating_Centre_Thermostat_Mode "LR_Heating_Centre Thermostat mode" <line> (HEATING_LR) {channel="zwave:device:011bc32e:node2:thermostat_mode"}
Number LR_Heating_Centre_Setpoint_Heating "LR_Heating_Centre Setpoint (heat)" <temperature> (HEATING_LR) {channel="zwave:device:011bc32e:node2:thermostat_setpoint_heating"}
Number LR_Heating_Centre_Setpoint_Furnace "LR_Heating_Centre Setpoint (energy heat)" <temperature> (HEATING_LR) {channel="zwave:device:011bc32e:node2:thermostat_setpoint_furnace"}
Switch LR_Heating_Centre_Alarm_System "LR_Heating_Centre Alarm (system)" <siren> (HEATING_LR) {channel="zwave:device:011bc32e:node2:alarm_system"}
Switch LR_Heating_Centre_Alarm_Power "LR_Heating_Centre Alarm (power)" <siren> (HEATING_LR) {channel="zwave:device:011bc32e:node2:alarm_power"}
Number LR_Heating_Centre_Battery_Level "LR_Heating_Centre Battery level" <line> (HEATING_LR) {channel="zwave:device:011bc32e:node2:battery_level"}
Dimmer LR_Heating_Right_Dimmer "LR_Heating_Right Dimmer" <"signal-3"> (HEATING_LR) {channel="zwave:device:011bc32e:node3:switch_dimmer"}
Number LR_Heating_Right_Sensor_Temperature "LR_Heating_Right Current temperature" <temperature> (HEATING_LR) {channel="zwave:device:011bc32e:node3:sensor_temperature"}
Number LR_Heating_Right_Thermostat_Mode "LR_Heating_Right Thermostat mode" <line> (HEATING_LR) {channel="zwave:device:011bc32e:node3:thermostat_mode"}
Number LR_Heating_Right_Setpoint_Heating "LR_Heating_Right Setpoint (heat)" <temperature> (HEATING_LR) {channel="zwave:device:011bc32e:node3:thermostat_setpoint_heating"}
Number LR_Heating_Right_Setpoint_Furnace "LR_Heating_Right Setpoint (energy heat)" <temperature> (HEATING_LR) {channel="zwave:device:011bc32e:node3:thermostat_setpoint_furnace"}
Switch LR_Heating_Right_Alarm_System "LR_Heating_Right Alarm (system)" <siren> (HEATING_LR) {channel="zwave:device:011bc32e:node3:alarm_system"}
Switch LR_Heating_Right_Alarm_Power "LR_Heating_Right Alarm (power)" <siren> (HEATING_LR) {channel="zwave:device:011bc32e:node3:alarm_power"}
Number LR_Heating_Right_Battery_Level "LR_Heating_Right Battery level" <line> (HEATING_LR) {channel="zwave:device:011bc32e:node3:battery_level"}
I would like to have two switches:
- Toggle thermostat_setpoint_heating between 17 and 21 for all members of HEATING_LRK
- Toggle thermostat_setpoint_heating between 17 and 20 for all members of HEATING_B
For now this is all I want to set up. Would someone kindly give me a hand? The sitemap generated by Home Builder confuses me more than it helps.
Thank you very much!
