Control Somfy My Position with Alexa voice control
Hello everyone,
I have linked my Somfy roller blind and raffstore motors with Alexa voice control, which is relatively easy to do by adding the Amazon Alexa Metadata. I can now move my blinds up, down or by percentage using voice control, and the slats can also be adjusted by voice command.
Unfortunately, I can’t manage to move the saved MY position via voice command. I have tried to add the command via actionMappings in the Alexa Metadata:
value: Blind.PositionState
  name: Jalousie Arbeitszimmer
  actionMappings:
    - Close=DOWN
    - Open=UP
    - Lower=DOWN
    - Raise=UP
    - Stop=STOP
    - My=MOVE
The send command ‘MOVE’ is used to successfully move to the saved MY position of the devices, e.g. via rules or scripts:
items.getItem('Jalousie_Arbeitszimmer__Control').sendCommand('MOVE');
It may not work with the added actionMapping via voice command. Does anyone have a hint as to what might be missing or has this already been successfully implemented?
Regards
neuling10
