Hello experts,
I´m struggeling with Openhab 2 while trying to setup a control-switch based on my Vimar (“light KNX system”) wall switches.
I am already using KNX binding for all my lights and rollershutters. This is working fine.
So I am using ETS to find out the Source Address of the wall switch - in my case it´s 1.0.36 when I hit the button (on or off) - there is just this value in Vimar - no status address.
So I setup a new knx bridge things file in ROUTER mode (my other KNX Things file for lights/rollershutter is in TUNNEL mode):
Things:
Bridge knx:ip:RasPI [
type="ROUTER",
ipAddress="224.0.23.12",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=60
Thing device generic [
readInterval=3600
Type switch-control : switch_office "Switch Office" [ ga="1/0/36" ]
Items:
Switch switch_office "Switch Office" {channel="knx:device:RasPI:generic:switch_office" }
The thing is I get no updates on my item or in the logs. I just want to retrieve the information that the wall switch is pressed and work with that information to turn on e.g. some hue lights or anything else.
The only thing I get in the logs is that the Light was turned on because the actuator is already binded:
Licht_Buero changed from OFF to ON
Can somebody help me to get this to work?
Thank you.
