Control Tasmota timers via MQTT
I’m glad it helped! I use the above together with presence detection - I don’t trigger it from any UI.
In general:
  • IF family members are home THEN dis-arm timers
  • IF family members are not home THEN arm timers
My presence detection is based entirely on this post:
OpenHAB detects whether a family member is home based on if their phone is connected to the home wifi.
Below is how I’ve implemented it.
Prerequisites
  • Network binding installed in OpenHab
    • PaperUI → Add-ons → Bindings → I’m glad it helped! I use the above together with presence detection - I don’t trigger it from any UI.
Configuration files
network.things
Change the IP addresses below to those which match those of your phones.
network:pingdevice:dDadAndroid [ hostname="192.168.1.99", retry=1, timeout=5000, refreshInterval=60000 ]
network:pingdevice:dMumAndroid [ hostname="192.168.1.78", retry=1, timeout=5000, refreshInterval=60000 ]
network.items
Switch sPresence "Someone is present"
Group:Switch:AND(OFF,ON) gPresenceSensors
Switch sPresenceTimer { expire="5m,command=OFF" }
Switch sDadAndroid (gPresenceSensors) { channel="network:pingdevice:dDadAndroid:online" }
DateTime dtDadAndroid { channel="network:pingdevice:dDadAndroid:lastseen" }
Switch sMumAndroid (gPresenceSensors) { channel="network:pingdevice:dMumAndroid:online" }
DateTime dtMumAndroid { channel="network:pingdevice:dMumAndroid:lastseen" }
lights.items
Group:Switch:OR(ON,OFF) gAwayLightTimers
Switch sBedroomSideLight "Bedroom Side Light" { channel="mqtt:topic:swBedroomSideLight:switch" }
String strBedroomSideLightTimer1 "Bedroom Side Light" { channel="mqtt:topic:swBedroomSideLight:timer1" }
String strBedroomSideLightTimer2 "Bedroom Side Light" { channel="mqtt:topic:swBedroomSideLight:timer2" }
String strBedroomSideLightTimer3 "Bedroom Side Light" { channel="mqtt:topic:swBedroomSideLight:timer3" }
String strBedroomSideLightTimer4 "Bedroom Side Light" { channel="mqtt:topic:swBedroomSideLight:timer4" }
presence.rules
This is almost exactly the same as the Rules DSL in the post I linked above, just with the Items slightly re-named to match the network.items file.
rule "Reset Presence and sensors to OFF on startup"
    System started
    sPresence.sendCommand(OFF)
    gPresenceSensors.sendCommand(OFF)
rule "A presence sensor was updated"
        Item gPresenceSensors changed
    if(sPresenceTimer.state == ON && gPresenceSensors.state == sPresence.state) {
        //logInfo("presence-rules", "Timer is running but group and proxy are the same, cancelling timer")
        sPresenceTimer.postUpdate(OFF)
    else if(gPresenceSensors.state == sPresence.state) {
        //logInfo("presence-rules", "No timer and both group and proxy are the same, nothing to do")
        return;
    if(gPresenceSensors.state == OFF) {
        //logInfo("presence-rules", "Everyone is away, setting anti-flapping timer")
        sPresenceTimer.sendCommand(ON)
    else if(gPresenceSensors.state == ON) {
        //logInfo("presence-rules", "Someone came home, setting presence to ON")
        sPresence.sendCommand(ON)
rule "Presence timer expired, no one is home"
    Item sPresenceTimer received command OFF
    //logInfo("presence-rules", "Everyone is still away, setting presence to OFF")
lights.rules
//PRESENCE BASED RULES
//ARM LIGHT TIMERS
rule "Arm light timers group when presence is not detected"
	Item sPresence changed
	if(sPresence.state==OFF){
		gAwayLightTimers.sendCommand(ON)
	else{
		gAwayLightTimers.sendCommand(OFF)
rule "Arm light timers"
	Item gAwayLightTimers changed to ON
	//ARM sBedroomSideLight TO TURN ON AT 1845 +/-15MINS, TURN OFF AT 1930 +/-15MINS, TURN ON 2145 /-15MINS, TURN OFF 2230+/-15MINS
	strBedroomSideLightTimer1.sendCommand("{\"Arm\":1,\"Mode\":0,\"Time\":\"18:45\",\"Window\":15,\"Days\":\"1111111\",\"Repeat\":1,\"Output\":1,\"Action\":1}")
	strBedroomSideLightTimer2.sendCommand("{\"Arm\":1,\"Mode\":0,\"Time\":\"19:30\",\"Window\":15,\"Days\":\"1111111\",\"Repeat\":1,\"Output\":1,\"Action\":0}")
	strBedroomSideLightTimer3.sendCommand("{\"Arm\":1,\"Mode\":0,\"Time\":\"21:45\",\"Window\":15,\"Days\":\"1111111\",\"Repeat\":1,\"Output\":1,\"Action\":1}")
	strBedroomSideLightTimer4.sendCommand("{\"Arm\":1,\"Mode\":0,\"Time\":\"22:30\",\"Window\":15,\"Days\":\"1111111\",\"Repeat\":1,\"Output\":1,\"Action\":0}")
rule "Disarm light timers"
	Item gAwayLightTimers changed to OFF
	//DISARM
	var jsonString = "{\"Arm\":0,\"Repeat\":0}"
	strBedroomSideLightTimer1.sendCommand(jsonString)
	strBedroomSideLightTimer2.sendCommand(jsonString)
	strBedroomSideLightTimer3.sendCommand(jsonString)
	strBedroomSideLightTimer4.sendCommand(jsonString)
sitemap snippets
I have two sitemaps. The normal one doesn’t show any of the above. I use a debug one to monitor what’s going on. Some snippets below.
Frame label="Upstairs lights"{
	Switch item=sBedroomSideLight label="Bedroom side" icon="light"
Frame label="Devices"{
	Text item=sDadAndroid label="Dad's phone [%s]" icon="boy_3"
	Text item=dtDadAndroid label="Last seen [%1$ta %1$tR]" icon="time"
	Text item=sMumAndroid label="Mum's phone [%s]" icon="girl_2"
	Text item=dtMumAndroid label="Last seen [%1$ta %1$tR]" icon="time"
Frame label="Debug"{
	Switch item=sPresence label="sPresence [%s]"
	Switch item=sPresenceTimer label="sPresenceTimer [%s]"
	Switch item=gPresenceSensors label="gPresenceSensors [%s]"
	Switch item=gAwayLightTimers label="gAwayLightTimers  [%s]"
Hope this helps!
