I installed the shelly dimmer 2 and related binding… it works properly…Now I would control the brightness with rules…I would like to:
retreive the actual value of the brightness
modify it, increase/descrese of 10% for example
send the command to set the dimmer with new value
I added in the things file the following: Thing shelly:shelly:shellydimmer-relay:40f52000dc53 "Shelly dimmer 2 Relay 40f52000dc53" @ "Camera" [deviceIp="192.168.1.34", userId="myshellyaccount", password="mypass"]
in the items:
Dimmer DimmerShelly “Dimmer Camera[%d %%]” (Camera) {channel=“shelly:shellydimmer:40f52000dc53:relay#brightness”}
Dimmer DimmerIncDec “Dimmer Light +/-” {channel=“shelly:shellydimmer:40f52000dc53:relay#brightness”}
I had interconnected my KNX trigger, I have an event that I can use to trigger the change in brightness, the problem here is how to correctly set up/change brightness value…
