Pretty much as the title says really!
There are multiple instances where I may want to control multiple things from a single widget in HABPanel. The best and most obvious example of this is to have a single slider which can dim all three Philips Hue bulbs in one room - who would want to do them individually?!. I’ve looked at rules, and set up a rule so if bulb 1 turns on or off, bulb 2 and 3 will follow suit - and when it works, it takes 5-10+ seconds for bulbs 2 and 3 to respond. For dimming this is no good to me, I want all three to respond simultaniously (and ideally near-instantly, I don’t mind a second or so of delay but not 5-10 seconds)
So, what’s my best approach? It seems kind of odd that you can’t add multiple actions to a single widget directly in the GUI - is that a planned feature maybe?
