i found the Wiki entry “Controlling openHAB with your voice” It works fine, until the RGB part.
} else if (command.contains("rot")) {
newState = new HSBType(new Color(255, 0, 0));
} else if (command.contains("blau")) {
newState = new HSBType(new Color(0, 0, 255));
} else if (command.contains("weiß")) {
newState = new HSBType(new Color(255, 255, 255));
When i place the voice command “licht flur rot” i recived.
2016-03-09 06:17:15.331 [INFO ] [openhab.model.script.Voice.Rec] - VoiceCommand received licht flur rot
2016-03-09 06:17:15.348 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Voice control'
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getRawType(JavaReflectAccess.java:107) ~[na:na]
at org.eclipse.xtext.common.types.util.JavaReflectAccess.getConstructor(JavaReflectAccess.java:90) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateConstructorCall(XbaseInterpreter.java:511) ~[na:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.7.0_79]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) ~[na:1.7.0_79]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.7.0_79]
at java.lang.reflect.Method.invoke(Method.java:606) ~[na:1.7.0_79]
Does anybody now what happen ?
Thanks regards Mario
