set ip_addr to your local IP address and mac_addr to your local MAC address
at the end of the function:
local_ip="192.168.x.x"
mac_addr=“xx:xx:xx:xx:xx:xx”
run “./entertain_control.sh log status”
please also run the commands above and send the output
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether b8:ae:ed:70:16:25 brd ff:ff:ff:ff:ff:ff
as far as I can see the response is returned from the receiver. It’s a valid soap response with result -2 (which then gets correctly parsed and displayed).
make sure that the receiver is powered on (to simplify the test case)
search for “# Subscribe to Pairing events”
and insert the line
Now I also had the time to run some first tests. The behaviour in my environment is exactly the same.
I am using a Raspberry Pi with Raspian and a wifi connection. Therefore I changed the script in order to retrieve the mac address of the WLAN adapter.
I also had to change the log output to /dev/stdout because the configured log path does not exist in my environment.
My receiver ist powered on and I tried at first the command statusand this is the result:
root@raspi3:~# ./entertain_control.sh log status
Telekom Entertain Control
TMP-Dir=/root/tmp
:49154 -> 192.168.2.104:49152; local MAC=B8:27:EB:BD:3F:9B
/dev/stdout
terminalID='AE0ED9A19F15D65C4C3022EEB9AA0C48'
Receiver is powered ON
ON
Then I tried to power it off with the off command.And this is the result:
root@raspi3:~# ./entertain_control.sh log off
TMP-Dir=/root/tmp
/dev/stdout
Listening on [0.0.0.0] (family 0, port 49154)
Send pairing request (pairingDeviceID='AE0ED9A19F15D65C4C3022EEB9AA0C48', friendlyName='oh-pi', userID='5903A68E8E31CF7EFC9718C635FC037D')
Result=-2
Pairing request failed: -2
Press Power/result>
Send key '0x0100'
Result=
OFF
hmm, the only thing which is static is the user id. I need to play here.
maybe also a setting of the receiver could have an effect? (are there any security related settings). It’s hard to guess what -2 means without any documentation.
thought about the user id topic. So far as I know the receiver has no concepts of users, but is in some way related to your Telekom line, so maybe this is a hash of your Telekom user id?
I can’t remember if I need to enter user credentials while configuring the receiver, the App defiantly requires to login when started first time.
